查看: 6343|回复: 2
[原创] Virtuoso里T键出现问题,求解决
发表于 2011-2-23 09:48:41 | 显示全部楼层 |阅读模式
在Virtuoso里用T键抓取图层的时候,如果选择file:///C:\Program Files\Tencent\TM2009\Users\542299068\Image\6g4tg7sb)ioi}tak~r64wbj.jpg"select from overlaps"会出现下面的东西  *WARNING* icSetCurrentWindowTrig: An error occured while applying '_leWeChooseLayer' to
\o (db:59171884 (("A1" "drawing" "(unassigned)" ptrnum@0x89ecbf0) ("BC" "drawing" "(unassigned)" ptrnum@0x89ecbf8) ("TB" "drawing" "(unassigned)" ptrnum@0x89ecc00) ("DN" "drawing" "(unassigned)" ptrnum@0x89ecc08)))
\r t
怎么解决啊
发表于 2011-2-23 21:48:27 | 显示全部楼层
_leWeChooseLayer
在快捷键文件里把前面的 _ 去掉试一下
发表于 2011-7-5 15:57:03 | 显示全部楼层
GMT+8, 2025-12-29 01:25 , Processed in 0.021983 second(s), 6 queries , Gzip On, Redis On.
