楼主: shaweikang1984
[资料] Low-Phase-Noise All-Digital Frequency Synthesizer With a Time-Windowed TDC
发表于 2011-6-3 07:28:24 | 显示全部楼层
good paper and thanks so much
发表于 2011-6-3 08:56:39 | 显示全部楼层
好资料,谢谢
发表于 2011-9-24 07:05:57 | 显示全部楼层
Abstract—A 2.1-to-2.8-GHz low-power consumption all-digital
phase locked loop (ADPLL) with a time-windowed time-to-digital
converter (TDC) is presented. The time-windowed TDC uses
a two-step structure with an inverter- and a Vernier-delay timequantizer
to improve time resolution, which results in low phase
noise. Time-windowed operation is implemented in the TDC, in
which a single-shot pulse-based operation is used for low power
consumption. The test chip implemented in 90-nm CMOS technology
exhibits in-band phase noise of 105 dBc Hz, where the
loop-bandwidth is set to 500 kHz with a 40-MHz reference signal,
and out-band noise of 115 dBc Hz at a 1-MHz offset frequency.
The chip core occupies 0.37 mm􀀀 and the measured power consumption
is 8.1 mA from a 1.2-V power supply.
发表于 2011-9-25 05:42:44 | 显示全部楼层
xuexile....
发表于 2012-2-7 15:42:47 | 显示全部楼层
Thanks for your sharing!
发表于 2012-9-28 13:18:41 | 显示全部楼层
is it a paper or what?
发表于 2013-3-20 14:16:49 | 显示全部楼层
dhfdhfh桑德菲杰阿萨德将加快了坚实的反馈
发表于 2013-4-21 15:45:55 | 显示全部楼层
Paper or Book?
发表于 2013-4-28 06:42:47 | 显示全部楼层
有趣的東西.....
发表于 2013-8-1 04:55:04 | 显示全部楼层
重要的學習材料........
GMT+8, 2025-12-26 18:14 , Processed in 0.022709 second(s), 5 queries , Gzip On, Redis On.
