查看: 26932|回复: 73
[资料] Low-Phase-Noise All-Digital Frequency Synthesizer With a Time-Windowed TDC
发表于 2011-1-31 10:51:31 | 显示全部楼层 |阅读模式
Abstract
A 2.1-to-2.8-GHz low-power consumption all-digital
phase locked loop (ADPLL) with a time-windowed time-to-digital
converter (TDC) is presented. The time-windowed TDC uses
a two-step structure with an inverter- and a Vernier-delay timequantizer
to improve time resolution, which results in low phase
noise. Time-windowed operation is implemented in the TDC, in
which a single-shot pulse-based operation is used for low power
consumption. The test chip implemented in 90-nm CMOS technology
exhibits in-band phase noise of 105 dBc Hz, where the
loop-bandwidth is set to 500 kHz with a 40-MHz reference signal,
and out-band noise of 115 dBc Hz at a 1-MHz offset frequency.
The chip core occupies 0.37 mm􀀀 and the measured power consumption
is 8.1 mA from a 1.2-V power supply.
abbr_c2e7353a8baea2805851b78bbd66a5b0.pdf (1.5 MB , 下载次数: 425 )
发表于 2011-1-31 11:08:09 | 显示全部楼层
goodreference for DLL  design
发表于 2011-1-31 11:39:00 | 显示全部楼层
thanks !9
发表于 2011-1-31 12:32:56 | 显示全部楼层
好资料,谢谢
发表于 2011-1-31 12:56:09 | 显示全部楼层
谢谢啊
发表于 2011-1-31 14:22:45 | 显示全部楼层
谢谢分享
发表于 2011-1-31 18:11:26 | 显示全部楼层
dign kan kan
发表于 2011-1-31 23:28:23 | 显示全部楼层
xuexi xuexi~
发表于 2011-2-1 17:18:50 | 显示全部楼层
kan e kan
发表于 2011-2-1 17:31:52 | 显示全部楼层
回复了再看
GMT+8, 2025-12-22 14:06 , Processed in 0.029264 second(s), 9 queries , Gzip On, Redis On.
