查看: 37257|回复: 150
[原创] 【Springer 2011 新书】Smart and Flexible Digital-to-Analog Converters
发表于 2011-1-17 18:48:30 | 显示全部楼层 |阅读模式
Smart and Flexible Digital-to-Analog Converters proposes new concepts and implementations for flexibility and self-correction of current-steering digital-to-analog converters (DACs) which allow the attainment of a wide range of functional and performance specifications, with a much reduced dependence on the fabrication process. DAC linearity is analysed with respect to the accuracy of the DAC unit elements. A classification is proposed of the many different current-steering DAC correction methods. The classification reveals methods that do not yet exist in the open literature. Further, this book systematically analyses self-calibration correction methods for the various DAC mismatch errors. For instance, efficient calibration of DAC binary currents is identified as an important missing method. This book goes on to propose a new methodology for correcting mismatch errors of both nominally identical unary as well as scaled binary DAC currents. A new concept for DAC flexibility is presented. The associated architecture is based on a modular design approach that uses parallel sub-DAC units to realize flexible design, functionality and performance. Two main concepts, self-calibration and flexibility, are demonstrated in practice using three DAC testchips in 250nm, 180nm and 40nm standard CMOS. Smart and Flexible Digital-to-Analog Converters will be useful to both advanced professionals and newcomers in the field. Advanced professionals will find new methods that are fully elaborated from analysis at conceptual level to measurement results at test-chip level. New comers in the field will find structured knowledge of fully referenced state-of-the art methods with many fully explained novelties.
Smart and Flexible Digital-to-Analog Converters.rar
7.16 MB, 下载次数: 1405 , 下载积分: 资产 -3 信元, 下载支出 3 信元
发表于 2011-1-17 20:01:49 | 显示全部楼层
thanks !
发表于 2011-1-17 20:04:36 | 显示全部楼层
good reference for DA design
发表于 2011-1-17 20:09:10 | 显示全部楼层
呵呵,谢谢楼主的分享
发表于 2011-1-17 20:18:30 | 显示全部楼层
thanks a lot
发表于 2011-1-17 20:26:28 | 显示全部楼层
谢谢!!!
发表于 2011-1-17 21:40:17 | 显示全部楼层
谢谢!!
发表于 2011-1-17 21:53:32 | 显示全部楼层
thanks
发表于 2011-1-18 04:12:17 | 显示全部楼层
ding kan kan
发表于 2011-1-18 04:52:15 | 显示全部楼层
thanks
GMT+8, 2025-12-15 14:00 , Processed in 0.023527 second(s), 7 queries , Gzip On, Redis On.
