查看: 2975|回复: 3
ICC problem
发表于 2011-1-13 14:36:32 | 显示全部楼层 |阅读模式
As attachment, there is a ICC error "PSYN-117"
It is because of the port connedts with multiple macro-cell pin.
Can someone help to give a solution?
My ICC version is 2009.06-SP5.
And , this case is OK for Astro.
ICC_question_2.pdf (110.32 KB , 下载次数: 23 )
 楼主| 发表于 2011-1-18 15:56:41 | 显示全部楼层
This issues has been solved  by using create_port command and set attribute to fixed.
发表于 2012-6-3 16:07:58 | 显示全部楼层
If macro include pad .... in .lib file add "pad_cell : true;" to cell,
and add "is_pad : true;" to pin, then re-gen. .db to ICC.
This issue will be fixed.
发表于 2015-1-9 11:55:32 | 显示全部楼层
回复 2# wilson168
   我也与到了同样的错误,不太看懂你是怎么解决的,能详细讲讲吗?
GMT+8, 2025-12-22 03:00 , Processed in 0.016950 second(s), 5 queries , Gzip On, Redis On.
