查看: 6362|回复: 8
[招聘] 经典IC设计面试问题12
发表于 2010-11-28 07:13:16 | 显示全部楼层 |阅读模式
What are Different types of Verilog Simulators ?
There are mainly two types of simulators available.
Event Driven
Cycle Based
Event-based Simulator:
This Digital Logic Simulation method sacrifices performance for rich functionality: every active signal is calculated for every device it propagates through during a clock cycle. Full Event-based simulators support 4-28 states; simulation of Behavioral HDL, RTL HDL, gate, and transistor representations; full timing calculations for all devices; and the full HDL standard. Event-based simulators are like a Swiss Army knife with many different features but none are particularly fast.
Cycle Based Simulator:
This is a Digital Logic Simulation method that eliminates unnecessary calculations to achieve huge performance gains in verifying Boolean logic:
1.) Results are only examined at the end of every clock cycle; and
2.) The digital logic is the only part of the design simulated (no timing calculations). By limiting the calculations, Cycle based Simulators can provide huge increases in performance over conventional Event-based simulators.
Cycle based simulators are more like a high speed electric carving knife in comparison because they focus on a subset of the biggest problem: logic verification.
Cycle based simulators are almost invariably used along with Static Timing verifier to compensate for the lost timing information coverage.
发表于 2010-11-28 14:30:21 | 显示全部楼层
多谢楼主分享!
发表于 2010-12-5 21:15:36 | 显示全部楼层
多谢楼主分享!
发表于 2011-1-20 19:00:05 | 显示全部楼层
这个问题不错,谢谢分享啊
发表于 2011-1-20 21:36:29 | 显示全部楼层
thanks for your sharing
发表于 2011-6-13 19:45:19 | 显示全部楼层
thank you very much, sir
发表于 2011-6-22 15:32:38 | 显示全部楼层
感謝分享
发表于 2011-7-18 10:18:53 | 显示全部楼层
呵呵,看看这个完整的回答
发表于 2011-8-1 20:22:21 | 显示全部楼层
呵呵,看看这个完整的回答
GMT+8, 2025-12-23 16:40 , Processed in 0.028934 second(s), 5 queries , Gzip On, Redis On.
