查看: 4604|回复: 3
[求助] Encounter中的CTS问题
发表于 2010-11-15 22:33:51 | 显示全部楼层 |阅读模式
最近小弟刚开始学习布局布线没多久,碰到许多问题。在一次使用Encounter时,用三层版进行布局布线的时候没什么问题,之后改用两层版,在做完CTS后发现版图内有很多红色菱形,不论怎么增加版图的面积,还是有许多。想问一下:
1.这些红色菱形是指什么错误,其中的V:16/9  H:10/8之类的是代表什么意思?
2.如何才能避免这种情况?在插时钟树前有什么需要注意的吗?
发表于 2010-11-16 13:57:46 | 显示全部楼层
1.it is visually check the congestion statistics.  by trial route generate congestion.
Eg: V=44/40 H=16/18
The vertical(V) overflow is 44/40 (44 tracks are required, but only 40 tracks are available)
The Horizontal(H) overflow is 16/18 (16 tracks are required, and 18 tracks are available)
2. fix it as following step:
I. Can adjust block placements and/or orientations to make sure that connecting pins also face each other.
II.Can use a partial placement blockage to lower the congestion in a specific area.
III.Read the log file for horizontal and vertical overflow numbers(%), where 1.0% is the  limit for 5+ metal layers and 0.5% is the limit for 3 layers. These are optimal limits for proceeding to detail routing.
发表于 2010-11-16 14:27:04 | 显示全部楼层
congestion
 楼主| 发表于 2010-11-16 15:17:17 | 显示全部楼层
谢谢1楼大侠的指点,我再去试试。
GMT+8, 2025-12-8 05:18 , Processed in 0.017560 second(s), 7 queries , Gzip On, Redis On.
