查看: 3109|回复: 5
[求助] 【在线求助】煎熬啊!DC安装了三天,到最后又出错,求助高手
发表于 2010-5-30 15:07:20 | 显示全部楼层 |阅读模式
安装DC安装了三天,最后在终端输入:dv&,结果显示下面的错误提示,请高手指点,是哪里出错了?是license没制作好?还是环境变量设置的问题?抑或是……?不胜感激!!!
[rootlocalhost bin]# dv&
[1] 4166
[root@localhost bin]# Unable to obtain feature 'Design-Vision ' because:
Error: This site is not licensed for 'Design-Vision'. (SEC-51)
Please contact  at root@localhost, who is
your local Synopsys license administrator for Synopsys site 000.
Unable to obtain feature 'Design-Analyzer ' because:
Error: This site is not licensed for 'Design-Analyzer'. (SEC-51)
Fatal: At least one of the following must be enabled : Design-Vision, Design-Analyzer. (DCSH-10)
[1]+  Exit 255                /usr/synopsys/B-2008.09/bin/design_vision
 楼主| 发表于 2010-5-30 18:22:47 | 显示全部楼层
在终端输入 lmli2 后,查看license的启动信息如下:
18:17:59 (lmgrd) -----------------------------------------------
18:17:59 (lmgrd)   Please Note:
18:17:59 (lmgrd)
18:17:59 (lmgrd)   This log is intended for debug purposes only.
18:17:59 (lmgrd)   In order to capture accurate license
18:17:59 (lmgrd)   usage data into an organized repository,
18:17:59 (lmgrd)   please enable report logging. Use Macrovision's
18:17:59 (lmgrd)   software license administration  solution,
18:17:59 (lmgrd)   FLEXnet Manager, to  readily gain visibility
18:17:59 (lmgrd)   into license usage data and to create
18:17:59 (lmgrd)   insightful reports on critical information like
18:17:59 (lmgrd)   license availability and usage. FLEXnet Manager
18:17:59 (lmgrd)   can be fully automated to run these reports on
18:17:59 (lmgrd)   schedule and can be used to track license
18:17:59 (lmgrd)   servers and usage across a heterogeneous
18:17:59 (lmgrd)   network of servers including Windows NT, Linux
18:17:59 (lmgrd)   and UNIX. Contact Macrovision at
18:17:59 (lmgrd)   www.macrovision.com for more details on how to
18:17:59 (lmgrd)   obtain an evaluation copy of FLEXnet Manager
18:17:59 (lmgrd)   for your enterprise.
18:17:59 (lmgrd)
18:17:59 (lmgrd)
18:17:59 (lmgrd)
18:17:59 (lmgrd) The license server manager (lmgrd) running as root:
18:17:59 (lmgrd)         This is a potential security problem
18:17:59 (lmgrd)         and is not recommended.
18:17:59 (lmgrd) Failed to open the TCP port number in the license.
请高手指点,不胜感激!!!
 楼主| 发表于 2010-5-31 21:33:14 | 显示全部楼层
在线等待! 不胜感激!!!
 楼主| 发表于 2010-6-1 22:06:45 | 显示全部楼层
期待高手指点!
发表于 2012-7-27 17:26:59 | 显示全部楼层
哥哥,这个问题您解决了吗?我用installer v2.2装的,设置完环境变量也是这个问题,请问有什么办法解决吗?非常非常感谢!!
发表于 2014-3-6 10:18:23 | 显示全部楼层
me too
GMT+8, 2025-12-23 15:39 , Processed in 0.020390 second(s), 5 queries , Gzip On, Redis On.
