查看: 3689|回复: 1
[原创] How to set power analysis corner?
发表于 2010-4-19 19:43:48 | 显示全部楼层 |阅读模式
1. First question is :
For power estimation, how to set power analysis corner?
Typical ? Worst?
2. For assumption, let's set typical case in power analysis. Then test silicon in lab environment, with typical power supply.
Would the two result correlate well? Need I consider IR Drop effect in sillicon?
Thanks.
发表于 2010-4-20 20:28:35 | 显示全部楼层
For Q1: That depends on the synthesis technology file you use for power estimation which provided by FAB .
GMT+8, 2025-12-31 06:56 , Processed in 0.017610 second(s), 6 queries , Gzip On, Redis On.
