查看: 4324|回复: 0
[求助] Quartus 7.2仿真时出现了以下者个提示,请问该怎么解决啊
发表于 2010-4-3 17:13:16 | 显示全部楼层 |阅读模式
之前的时候还没有,但不知啥时候就跳出来以下这个东东啦。
Info: Option to preserve fewer signal transitions to reduce memory requirements is enabled
Info: Simulation has been partitioned into sub-simulations according to the maximum transition count determined by the engine. Transitions from memory will be flushed out to disk at the end of each sub-simulation to reduce memory requirements.
随后,方针速度就变得超慢。
在设置里把参数 修改为OFF 后,还是超慢,真是纠结!!!
望大虾们赐教!!!
GMT+8, 2025-12-20 12:54 , Processed in 0.021109 second(s), 5 queries , Gzip On, Redis On.
