查看: 6748|回复: 9
[求助] 请教ic compiler里面tie hi、tie LOW 线的链接
发表于 2010-2-11 13:07:41 | 显示全部楼层 |阅读模式
warning: Cell contains tie connections which are not connected       to rea
l PG.
icc_shell> derive_pg_connection -power_net VDD -power_pin VDD -ground_net VS
S -ground_pin VSS -tie
begin derive_pg_connection...
-- reconnected total 0 tie highs and 0 tie lows
1
icc_shell> check_mv_design -power_nets
Warning: Total 89 logical library cell(s) used in the design do not have pow
er/ground pins. (MV-597)
Power/Ground Connection Summary:
P/G net name                P/G pin count
Unconnected power pins:           11268
Unconnected ground pins:          11268
Warning: Power connection/checking is skipped for 22536 power pins because t
he required power pin information cannot be found in logical libraries. (MV-
510)
No Errors/Warnings Found.
       Supply Operating Voltage Checks
Please review report above for warnings and errors.
1
foundry提供的library 就是这个了,好像也没有其他D的“ logical libraries    wi
th power pins.”
这个应该如何处理?谢谢
发表于 2012-1-9 15:23:37 | 显示全部楼层
回复 1# zzczx
    前辈 我也有设个问题   你的解决了吗   怎么解决的???
发表于 2012-1-15 17:39:46 | 显示全部楼层
同问~
发表于 2012-1-15 18:54:19 | 显示全部楼层
derive_pg_connections -power_net VDD -ground_net VSS -tie
成功以后,
connect_tie_cells 就能加tie cell了
你是multi power domain的 tie off  cell是吧
发表于 2012-1-17 11:10:33 | 显示全部楼层
我也遇到过这个问题,4#的方法就可以解决,可以先连pin,然后-tie
derive_pg_connection -power_net VDD -power_pin VDD -ground_net VSS -ground_pin VSS
发表于 2012-6-20 10:58:43 | 显示全部楼层
大侠,我也遇到这个问题,试了#5的方法还是不行Checking [VSS]:
        There are no floating shapes
        ERROR: There are 306 floating pins
Checking [VDD]:
Checked 2 nets, 2 have Errors
发表于 2014-1-14 10:47:38 | 显示全部楼层
回复 4# icfbicfb
我用
drive_pg_connection -power_net VDD  -power_pin VDD\                                -power_net VSS  -power_pin VSS\
                                -tie
时,出现reconnect total 0 tie highs and 0 tie lows
后来分别用
drive_pg_connection -power_net VDD  \                                -power_net VSS  \
                                -tie
可以连到power port
但提示connect 0 ground port
check_mv_design -power_nets(我的不是多电源设计)也提示
power connection/checking is skipped for 28101 power pins because the required power pin information cannot be found in logical libraries
请问下怎么解决呢
发表于 2014-2-27 21:58:35 | 显示全部楼层
回复 7# lilyzhong
也遇到了同样的问题,请教一下怎么解决呢,谢谢了!
发表于 2014-3-2 17:28:58 | 显示全部楼层
回复 8# 小_蜜_蜂
   能连上就可以了关于IO pad有时总提示P/G连不上,你到layout里看下确实连上了就行了
应该问题不大
发表于 2014-3-3 12:20:52 | 显示全部楼层
回复 9# lilyzhong
好像不是pad没连上,提示说 missing pg pin in logical library ,不知道怎么解决,多谢了
GMT+8, 2025-9-13 22:13 , Processed in 0.023412 second(s), 3 queries , Gzip On, Redis On.
