查看: 2557|回复: 0
[招聘] NO.16-GNU Toolchain Engineer(Shanghai)
发表于 2010-2-2 17:10:42 | 显示全部楼层 |阅读模式
Job Description:
The GNU Toolchain Engineer is more than just a compiler engineer, as their responsibilities extend from the GNU Compiler collection to GNU binutils (including the assembler, linker, symbol manager), GNU debugger (with insight support), and elf2flt (the translator from elf to the noMMU/uClinux file format) and various open source and propriatary libraries (libdsp, newlib, libgloss, uClibc). The candidate must have excellent C/C++ and assembly coding skills, be self-driven with high-quality deliveries and needing as little as possible input. Provide engineering support to customers in their applications or development environments. Verifies problems reported by customers. Highly technical, broad understanding of very complicated issues, but customer driven. Teaches customers on how to use our products. Diagnoses and debugs intricate and complex problems that customers are experiencing.
Requirement:
· BS/MS in Computer Science or related fields.
· Works well in a team environment
· Experience in writing and automating test scripts for regressions
· Knowledge of the embedded architectures (ARM or Blackfin preferred)
· C/C++ expertise as well as deep understanding of compilers and makefile.
· hands-on software development experience in a commercially deployed product.
· Experience developing and deploying products using gcc/Linux
· Experience in using and developing software development tools (track record of contributions in at least one of GCC, GAS, GDB and GNU Binutils)
· Full cycle of software development including detailed analysis, design, implementation, debugging and developer testing
· Bachelors in EE or CS
KT Human Resources Consulting Company (Shanghai) was established in 2001 in
response to a need for a recruitment consultancy to be an active, contributing
member of the semiconductor community, as opposed to simply a supplier to it.We
provide professional search and talent acquisition in the Integrated Circuit、
Electronic、Telecommunications industry of international corporations in Greater
China. Our client list contains numerous international companies, many of them
are long-term customers.
If you interested in the job, pls sent your cv to: hr@kthr.com, thanks!
GMT+8, 2025-10-25 01:30 , Processed in 0.019358 second(s), 5 queries , Gzip On, Redis On.
