查看: 5553|回复: 1
[求助] 求助! coverage测试时遇到的难题
发表于 2010-1-5 14:48:19 | 显示全部楼层 |阅读模式
在用NCverilog做覆盖率测试时,遇到一个奇怪的问题,即:在一个模块中多次调用另外一个模块的情况(例如:module a(....);.....B B_1(...); B  B_2(..); B B_3(...);...endmodule),加coverage命令产生dgn文件时,产生如下错误:
ncsim: *internal* (genuine access violation (0-9affb08:2)).
ncsim: *internal* (genuine access violation (0-57e153:2)).
Please contact Cadence Design Systems about this problem
and provide enough information to help us reproduce it.
ncsim: *internal* (NO ERROR for error code 0).
ncverilog: *E,SIMERR: Error during Simulation (status 1), exiting.
我加的coverage configuration file如下:
select_coverage -block -expr  -module *...
set_glitch_strobe 5ns
set_instance_context  A
set_hit_count_limit 4
set_implicit_block_scoring -on -both *
set_assign_scoring
TCL文件如下:
coverage -setup
coverage -code
run
exit
在此,请教大家,其原因是什么?该如何解决?谢谢大家乐
 楼主| 发表于 2010-1-5 17:58:39 | 显示全部楼层
原因好像不是嵌套调用引起的。。。。。真是晕哈
GMT+8, 2025-12-27 03:56 , Processed in 0.017307 second(s), 6 queries , Gzip On, Redis On.
