查看: 10422|回复: 36
Freesacle 功放管匹配 Impedance Matching Networks Applied to RF Power Transistors
发表于 2009-12-5 09:31:01 | 显示全部楼层 |阅读模式
功放管匹配 Impedance Matching Networks Applied to RF Power Transistors.pdf
725.11 KB, 下载次数: 422 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2009-12-5 09:32:06 | 显示全部楼层
初次发帖,希望大家多多关照。我发下这个的介绍
1. INTRODUCTION
Some graphic and numerical methods of impedance
matching will be reviewed here. The examples given will refer
to high frequency power amplifiers.
Although matching networks normally take the form of
filters and therefore are also useful to provide frequency
discrimination, this aspect will only be considered as a
corollary of the matching circuit.
Matching is necessary for the best possible energy
transfer from stage to stage. In RF-power transistors the
input impedance is of low value, decreasing as the power
increases, or as the chip size becomes larger. This
impedance must be matched either to a generator — of
generally 50 ohms internal impedance — or to a preceding
stage. Impedance transformation ratios of 10 or even 20 are
not rare. Interstage matching has to be made between two
complex impedances, which makes the design still more
difficult, especially if matching must be accomplished over
a wide frequency band.
发表于 2009-12-6 07:41:05 | 显示全部楼层
呵呵,帮楼主顶一个
发表于 2009-12-7 08:36:46 | 显示全部楼层
好书,谢谢楼主!
发表于 2009-12-7 20:09:30 | 显示全部楼层
号贴 懂啊 啊
发表于 2009-12-8 14:05:56 | 显示全部楼层
have a look
发表于 2010-2-12 11:20:52 | 显示全部楼层
have a look
发表于 2010-2-12 15:38:17 | 显示全部楼层
谢谢。。。。。。。
发表于 2010-2-17 13:20:07 | 显示全部楼层
ddddddddddddddddddddd
发表于 2010-2-27 08:43:16 | 显示全部楼层
好书,谢谢楼主
GMT+8, 2025-12-26 22:13 , Processed in 0.033058 second(s), 7 queries , Gzip On, Redis On.
