查看: 2315|回复: 1
Digital Communication over Fading Channels
发表于 2009-10-13 11:20:00 | 显示全部楼层 |阅读模式
Digital Communication over Fading Channels: A Unified Approach to Performance Analysis
Marvin K. Simon, Mohamed-Slim Alouini, «Digital Communication over Fading Channels: A Unified Approach to Performance Analysis»
John Wiley & Sons | ISBN: 0471317799 | 2000 | PDF | 544 pages | 4.36 MB
Regardless of the branch of science or engineering, theoreticians have always been enamored with the notion of expressing their results in the form of closed-form expressions. Quite often, the elegance of the closed-form solution is overshadowed by the complexity of its form and the difficulty in evaluating it numerically. In such instances, one becomes motivated to search instead for a solution that is simple in form and simple to evaluate. A further motivation is that the method used to derive these alternative simple forms should also be applicable in situations where closed-form solutions are ordinarily unobtainable.
http://uploading.com/files/829b5555/digital-communication-over-fading-channels-a-unified-approach-to-performance-analysis.9780471317791./
发表于 2010-3-6 15:52:35 | 显示全部楼层
谢啦    :)))
GMT+8, 2025-12-27 21:16 , Processed in 0.016575 second(s), 6 queries , Gzip On, Redis On.
