查看: 20365|回复: 45
一个恒定跨导的cmos运放
发表于 2009-10-10 19:36:05 | 显示全部楼层 |阅读模式
跨导恒定的原理不太懂,文章里说保持Ip+In=IT  可不知道为什么会相等,电路虚线部分不太懂
 楼主| 发表于 2009-10-10 19:39:27 | 显示全部楼层
这是图片
C:\Documents and Settings\Administrator\桌面
 楼主| 发表于 2009-10-10 19:42:22 | 显示全部楼层
怎么插图片啊?
 楼主| 发表于 2009-10-10 19:44:16 | 显示全部楼层
file:///C:/Documents ,这是图片
 楼主| 发表于 2009-10-10 19:49:15 | 显示全部楼层
我设的下载不要钱这是一篇IEEE论文,题目是1v rail to rail constant-gm cmos op amp 今年5月份的 getPDF.pdf (205.43 KB , 下载次数: 208 )
 楼主| 发表于 2009-10-10 21:29:08 | 显示全部楼层
帮帮忙了
发表于 2009-10-10 23:38:22 | 显示全部楼层
下载扣了5元
发表于 2009-10-11 01:40:02 | 显示全部楼层
发表于 2009-10-11 05:15:41 | 显示全部楼层
School paper, school paper, use it at your own risks!
I downloaded and read the paper, here's a summary of these two authors' ideas:
1. You need to push the two diff pairs M1-M2 and M4-M5 to weak inversion region;
2. Constant-gm is achieved by keeping the total tail currents of the two diff pairs constant (gm is proportional to the drain current);
3. The gm control circuit is a replica bias, and Ip is controlled by the input common mode voltage.
The Vibas for M7 & M8 could be more tricky, but the authors have never mentioned it in the paper.
So IMHO, if the headroom is not an issue, go for traditional ways to design constant-gm opamps.
 楼主| 发表于 2009-10-11 08:33:34 | 显示全部楼层
谢谢楼上的答复,m7,m8应该是一直被偏置在饱和状态吧,如果m4,m5截止的话,m1,m2,m7,m8不就是折叠式共源共栅结构吗,m7 ,m8的偏置应该好处理吧
站长推荐 上一条 /3 下一条
GMT+8, 2025-9-11 00:03 , Processed in 0.019298 second(s), 6 queries , Gzip On, Redis On.
