查看: 5053|回复: 12
一个看似简单的问题
发表于 2009-8-16 22:09:51 | 显示全部楼层 |阅读模式
reg型数据的默认初始值是不定值。reg型数据可以赋正值,也可以是负值。但当一个reg型数据是一个表达式中的操作数时,它的值被当作是无符号值,既是正值。例如,当一个4位寄存器用做表达式中的操作数时,如果开始寄存器被赋以值-1,则在表达式中进行运算时,其值被认为是+15。
请问为什么是15,如何得来的?
发表于 2009-8-17 00:14:50 | 显示全部楼层
in verilog 95, in fact, there's no such things about signed or unsigned numbers. It's just some bits.
e.g. reg[3:0] num;
initial begin
  num = 4'd15; // then num is 0xf.
end
And 0xf is simply 0x1's 2's complement...
in other words, say, would'd like to do something like:
reg[3:0] a;
reg[3:0] b;
reg[7:0] c;
initial begin
  a = -1;
  b = -1;
  c = a * b;
end
c would be 0xe1, not 1...
So you'd have to take care of your sign instead.
In v2k, it's better, there's a reserved word called signed.
reg[3:0] signed a;
reg[3:0] signed b;
reg[7:0] signed c;
now c = 1.
发表于 2009-8-17 01:49:00 | 显示全部楼层
负数是以补码存在的,-1的补码是11111111。
 楼主| 发表于 2009-8-17 08:45:12 | 显示全部楼层
-1的补码应该01111(寄存器4位,符号位1位)
发表于 2009-8-19 20:44:56 | 显示全部楼层
好东西阿
大家鼓掌
发表于 2009-9-23 14:17:37 | 显示全部楼层
111
发表于 2009-9-24 11:03:23 | 显示全部楼层
这是一个,看似简单,实际也很简单的问题。
发表于 2009-9-24 11:25:40 | 显示全部楼层
4楼哥们,汗一个,不要误导啊.....
看似简单,其实就是这么简单,4位操作数,-1 补码本来就是1111
发表于 2009-9-24 11:34:39 | 显示全部楼层
-1的8bit补码明显是11111111。
原码:1(符号位)000 0001
反码:1(符号位)111 1110
补码:1(符号位)111 1111(反码加1)
发表于 2009-9-26 18:03:04 | 显示全部楼层
补码a
GMT+8, 2025-12-26 03:00 , Processed in 0.026749 second(s), 5 queries , Gzip On, Redis On.
