查看: 2095|回复: 3
RF self test
发表于 2009-8-3 05:22:29 | 显示全部楼层 |阅读模式
This paper addresses a built-in self-test (BiST) for ICs
digital transceivers. The focus is on testing the RF frontend
while taking advantage of the on-chip DSP resources
and DA-, AD converters. The loopback architecture is
used to prevent the sensitive RF blocks from extra noise
and external disturbances. The test aims at spot defects
typical of RF CMOS ICs, where those faults are deemed
the main yield limiter in mass production. The fault model
is discussed at three levels of design abstraction: layout,
circuit and functional block. The BiST model is verified at
the circuit and functional level. As a demonstrator a GSM
transceiver model with loopback BiST is presented that
provides a promising result.
self_testing.pdf
4.06 MB, 下载次数: 34 , 下载积分: 资产 -3 信元, 下载支出 3 信元
RF_BIST_LNA.pdf
1.04 MB, 下载次数: 36 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2009-8-3 07:04:55 | 显示全部楼层
good stuffs thanks you!
发表于 2009-8-3 08:13:02 | 显示全部楼层
thanks
发表于 2009-8-3 08:14:23 | 显示全部楼层
thanks
GMT+8, 2025-10-6 02:47 , Processed in 0.024069 second(s), 9 queries , Gzip On, Redis On.
