发表于 2011-6-18 12:31:42
显示全部楼层
回复 5# nishuidegou
$ TMA TSUPREM-4 N-channel MOS application
$ 1. Identify the graphics driver
$ Default from DEFPDEV, TERM, or S4PCAP "default" entry used
$ 2. Beginning of the main loop
FOREACH LD ( 3 5 )
$ 3. Specify the mesh
MESH GRID.FAC=1.5
MESH DY.SURF=0.01 LY.SURF=0.04 LY.ACTIV=2.0
$ 4. Initialize
INITIALIZE <100> BORON=1E15 WIDTH=( 0.7 + ( LD / 10.0 ) ) DX=0.1
$ 5. Plot the initial mesh
SELECT TITLE="Mesh for Delta=0.@{LD}"
PLOT.2D SCALE GRID Y.MAX=3.0 C.GRID=2
$ 6. Initial oxide pad
DEPOSIT OXIDE THICKNESS=0.03
$ 7. P-well implant
IMPLANT BORON DOSE=1E12 ENERGY=35
$ 8. Use a point defect models that simulates OED
METHOD PD.TRANS
$ 9. P-well drive
DIFFUSE TEMP=1100 TIME=120 DRYO2 PRESS=0.02
$ 10. P-well doping profile
SELECT Z=LOG10(BORON) TITLE="Channel Doping (Delta=0.@{LD})"
PLOT.1D X.VALUE=0 RIGHT=3.0 BOTTOM=15 TOP=19 LINE.TYP=2 COLOR=2
LABEL X=1.8 Y=18.5 LABEL="After p-well drive" LINE.TYP=2 C.LINE=2
$ 11. Pad nitride
DEPOSIT NITRIDE THICKNESS=0.1
$ 12. Field implant and oxidation
IMPLANT BORON DOSE=5E13 ENERGY=80
DIFFUSE TEMP=1000 TIME=360 WETO2
$ 13. Etch to remove the pad
ETCH NITRIDE ALL
$ 14. Vt adjust implant
IMPLANT BORON ENERGY=100 DOSE=1E12
$ 15. P-well doping profile
PLOT.1D X.VALUE=0 ^AXES ^CLEAR COLOR=2
LABEL X=1.8 Y=18.2 LABEL="After Vt implant" LINE.TYP=1 C.LINE=2
$ 16. Print oxide and silicon thicknesses
SELECT Z=1
PRINT.1D X.VALUE=0.0 LAYERS
$ 17. Etch oxide
ETCH OXIDE TRAP THICK=0.05
$ 18. Gate oxidation
DIFFUSE TEMP=950 TIME=30 DRYO2
$ 19. Poly deposition
DEPOSIT POLYSILICON THICKNESS=0.3 DIVISIONS=4
$ 20. Poly and oxide etch between x = 0.0 and 0.5 microns
ETCH POLY LEFT P1.X=0.5
ETCH OXIDE TRAP THICK=0.04
$ 21. Deposit a thin layer of oxide
DEPOSIT OXIDE THICKNESS=0.02
$ 22. LDD implant
IMPLANT PHOS ENERGY=50 DOSE=5E13 IMPL.TAB=PHOSPHORUS
$ 23. LTO
DEPOSIT OXIDE THICK=0.2
$ 24. Establish a sidewall spacer
ETCH OXIDE TRAP THICK=0.22
$ 25. Source/drain implant
IMPLANT ARSENIC ENERGY=100 DOSE=2E15
$ 26. Oxide etch
ETCH OXIDE LEFT P1.X=0.5
$ 27. Use an oxidation model that understands polysilicon
METHOD COMPRESS
$ 28. Source/drain reoxidation (including the polysilicon gate)
DIFFUSE TEMP=900 TIME=30 DRYO2
$ 29. BPSG -- etch to open windows for aluminum contact
DEPOSIT OXIDE THICK=0.3
ETCH OXIDE LEFT P1.X=0.3
$ 30. Metallization -- etch to create a source contact
DEPOSIT ALUMINUM THICK=0.5 SPACES=3
DEPOSIT PHOTORESIST THICK=1.0
ETCH PHOTORESIST RIGHT P1.X=0.6
ETCH ALUMINUM TRAP ANGLE=85 THICK=0.8
ETCH PHOTORESIST ALL
$ 31. Reflect to form the complete structure; then save it
SAVEFILE OUT.FILE=S4EX7AS@LD
STRUCTURE REFLECT RIGHT
SAVEFILE OUT.FILE=S4EX7AP@LD MEDICI
savefile out.f=s4ex7a@{LD}.tif tif
$ 32. End of loop
END |
