查看: 8594|回复: 29
[Ebook]Building Embedded Linux Systems
发表于 2004-5-22 16:24:24 | 显示全部楼层 |阅读模式
Building Embedded Linux Systems shows you how to design and build your own embedded systems using Linux® as the kernel and freely available open source tools as the framework. Written by an active member of the open source community, the book is structured to gradually introduce readers to the intricacies of embedded Linux, with detailed information and examples in each chapter that culminate in describing how Linux is actually put on an embedded device.
Contents:
     Copyright
     Dedication
     Preface
        Audience of This Book
        Scope and Background Information
        Organization of the Material
        Hardware Used in This Book
        Software Versions
        Book Web Site
        Typographical Conventions
        Contact Information
        Acknowledgments
     Chapter 1.  Introduction
        Section 1.1.  Definitions
        Section 1.2.  Real Life and Embedded Linux Systems
        Section 1.3.  Example Multicomponent System
        Section 1.4.  Design and Implementation Methodology
     Chapter 2.  Basic Concepts
        Section 2.1.  Types of Hosts
        Section 2.2.  Types of Host/Target Development Setups
        Section 2.3.  Types of Host/Target Debug Setups
        Section 2.4.  Generic Architecture of an Embedded Linux System
        Section 2.5.  System Startup
        Section 2.6.  Types of Boot Configurations
        Section 2.7.  System Memory Layout
     Chapter 3.  Hardware Support
        Section 3.1.  Processor Architectures
        Section 3.2.  Buses and Interfaces
        Section 3.3.  I/O
        Section 3.4.  Storage
        Section 3.5.  General Purpose Networking
        Section 3.6.  Industrial Grade Networking
        Section 3.7.  System Monitoring
     Chapter 4.  Development Tools
        Section 4.1.  Using a Practical Project Workspace
        Section 4.2.  GNU Cross-Platform Development Toolchain
        Section 4.3.  C Library Alternatives
        Section 4.4.  Java
        Section 4.5.  Perl
        Section 4.6.  Python
        Section 4.7.  Ada
        Section 4.8.  Other Programming Languages
        Section 4.9.  Integrated Development Environments
        Section 4.10.  Terminal Emulators
     Chapter 5.  Kernel Considerations
        Section 5.1.  Selecting a Kernel
        Section 5.2.  Configuring the Kernel
        Section 5.3.  Compiling the Kernel
        Section 5.4.  Installing the Kernel
        Section 5.5.  In the Field
     Chapter 6.  Root Filesystem Content
        Section 6.1.  Basic Root Filesystem Structure
        Section 6.2.  Libraries
        Section 6.3.  Kernel Modules
        Section 6.4.  Kernel Images
        Section 6.5.  Device Files
        Section 6.6.  Main System Applications
        Section 6.7.  Custom Applications
        Section 6.8.  System Initialization
     Chapter 7.  Storage Device Manipulation
        Section 7.1.  MTD-Supported Devices
        Section 7.2.  Disk Devices
        Section 7.3.  To Swap or Not to Swap
     Chapter 8.  Root Filesystem Setup
        Section 8.1.  Selecting a Filesystem
        Section 8.2.  Using an NFS-Mounted Root Filesystem to Write a Filesystem Image to Flash
        Section 8.3.  CRAMFS
        Section 8.4.  JFFS2
        Section 8.5.  Disk Filesystem over NFTL
        Section 8.6.  Disk Filesystem over RAM Disk
        Section 8.7.  Mounting Directories on TMPFS
        Section 8.8.  Live Updates
     Chapter 9.  Setting Up the Bootloader
        Section 9.1.  Bootloaders Galore
        Section 9.2.  Server Setup for Network Boot
        Section 9.3.  Using LILO with Disk and CompactFlash Devices
        Section 9.4.  Using GRUB with DiskOnChip Devices
        Section 9.5.  U-Boot
     Chapter 10.  Setting Up Networking Services
        Section 10.1.  The Internet Super-Server
        Section 10.2.  Remote Administration with SNMP
        Section 10.3.  Network Login Through Telnet
        Section 10.4.  Secure Communication with SSH
        Section 10.5.  Serving Web Content Through HTTP
        Section 10.6.  Dynamic Configuration Through DHCP
     Chapter 11.  Debugging Tools
        Section 11.1.  Debugging Applications with gdb
        Section 11.2.  Tracing
        Section 11.3.  Performance Analysis
        Section 11.4.  Memory Debugging
        Section 11.5.  A Word on Hardware Tools
     Appendix A.  Worksheet
        Section A.1.  Project Identification
        Section A.2.  Hardware Summary
        Section A.3.  Development Tools
        Section A.4.  Kernel
        Section A.5.  Root filesystem
        Section A.6.  Storage Device Organization
        Section A.7.  Bootloader Configuration and Use
        Section A.8.  Networking services
        Section A.9.  Custom Project Software
        Section A.10.  Debug Notes
        Section A.11.  Additional Notes
        Section A.12.  Embedded Linux Systems Worksheet
     Appendix B.  Resources
        Section B.1.  Online
        Section B.2.  Books
        Section B.3.  Publications
        Section B.4.  Organizations
        Section B.5.  Linux and Open-Source-Oriented Hardware Projects
     Appendix C.  Important Licenses and Notices
        Section C.1.  Exclusion of User-Space Applications from Kernel's GPL
        Section C.2.  Notices on Binary Kernel Modules
        Section C.3.  Legal Clarifications About the Kernel by Linus Torvalds
     Colophon
     Index
 楼主| 发表于 2004-5-22 16:26:07 | 显示全部楼层
LBHIDDEN[0]LBHIDDENBuilding Embedded Linux Systems
By Karim Yaghmour
Publisher : O'Reilly
35_61_1.rar
1021.45 KB, 下载次数: 61 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2004-6-8 16:04:12 | 显示全部楼层
好书,多谢。
发表于 2004-6-15 14:31:19 | 显示全部楼层
怎一个好字了得!
发表于 2004-12-31 13:59:44 | 显示全部楼层
谢谢
发表于 2005-6-5 13:13:21 | 显示全部楼层
楼主真是太无私了,
发表于 2005-6-8 04:55:46 | 显示全部楼层
顶!
发表于 2005-6-8 09:25:23 | 显示全部楼层
thank you !
发表于 2005-6-10 11:32:30 | 显示全部楼层
谢谢
发表于 2005-10-15 15:59:16 | 显示全部楼层
太棒啦!
GMT+8, 2025-12-24 22:09 , Processed in 0.051459 second(s), 9 queries , Gzip On, Redis On.
