查看: 86164|回复: 535
Springer 2009新书,Dynamic Offset Compensated CMOS Amplifiers
发表于 2009-7-1 21:33:37 | 显示全部楼层 |阅读模式
[size=120%]Dynamic Offset Compensated CMOS Amplifiers (Analog Circuits and Signal Processing)
By Frerik Witte, Kofi Makinwa, Johan H. Huijsing
  • Publisher:   Springer
  • Number Of Pages:   200
  • Publication Date:   2009-09-01
  • ISBN-10 / ASIN:   9048127556
  • ISBN-13 / EAN:   9789048127559
Product Description:
Dynamic Offset-Compensated CMOS Amplifiers describes the theory, design and realization of dynamic offset compensated CMOS amplifiers. It focuses on the design of general-purpose wide-band operational amplifiers and instrumentation amplifiers.
Two offset compensation techniques are described: auto-zeroing and chopping. Several topologies are discussed, with which these techniques can be used in the design of wide-band dynamic offset-compensated amplifiers. Four implementations are discussed in detail: two low-offset wide-band operational amplifiers, a low-offset instrumentation amplifier, and a low-offset current-sense amplifier, which can sense the current drawn from supply voltages up to 28V .
Dynamic Offset Compensated CMOS Amplifiers.part1.rar
4.18 MB, 下载次数: 4321 , 下载积分: 资产 -3 信元, 下载支出 3 信元
Dynamic Offset Compensated CMOS Amplifiers.part2.rar
4.04 MB, 下载次数: 4163 , 下载积分: 资产 -3 信元, 下载支出 3 信元
发表于 2009-7-1 21:38:00 | 显示全部楼层
超新书啊
09出版
发表于 2009-7-1 21:42:04 | 显示全部楼层
Preface ..................................................................................................
Acknowledgements .......................................................................
1. Introduction ......................................................................................... 1
1.1 Motivation .............................................................................................. 1
1.2 Offset ...................................................................................................... 3
1.2.1 Drain current mismatch ................................................................. 4
1.2.2 Folded cascode amplifier offset ..................................................... 5
1.2.3 Minimizing offset .......................................................................... 6
1.3 Challenges .............................................................................................. 7
1.4 Organisation of the book ........................................................................ 8
1.5 References ............................................................................................ 10
2. Dynamic Offset Compensation Techniques ............... 13
2.1 Introduction .......................................................................................... 13
2.2 Auto-zero amplifiers ............................................................................. 14
2.2.1 Output offset storage ................................................................... 14
2.2.2 Input offset storage ...................................................................... 16
2.2.3 Auxiliary amplifier ...................................................................... 17
2.2.4 Noise in auto-zero amplifiers ...................................................... 19
2.3 Chopper amplifiers ............................................................................... 23
2.3.1 Noise in chopper amplifiers ......................................................... 25
2.3.2 Chopped operational amplifier in a feedback network ................ 26
2.3.3 Charge injection effects in chopper amplifiers ............................ 27
2.4 Chopped auto-zeroed amplifier ............................................................ 29
2.5 Switching non-idealities ....................................................................... 31
2.5.1 Charge injection reduction tactics ............................................... 33
2.5.2 Charge injection suppression circuits .......................................... 36
2.6 Conclusions .......................................................................................... 40
2.7 References ............................................................................................ 40
3. Dynamic Offset Compensated Operational
Amplifiers .............................................................................................................. 43
3.1 Introduction .......................................................................................... 43
3.2 Ping-pong operational amplifier .......................................................... 44
3.3 Offset-stabilized amplifiers .................................................................. 45
3.3.1 Auto-zero offset-stabilized amplifiers ......................................... 47
3.3.2 Chopper offset-stabilized amplifiers ........................................... 48
3.3.3 Frequency compensation ............................................................. 50
3.3.4 Chopper stabilized amplifiers with ripple filters ......................... 55
3.3.5 Chopper and auto-zero stabilized amplifiers ............................... 58
3.4 Chopper offset-stabilized chopper amplifiers ...................................... 59
3.4.1 Iterative offset-stabilization ........................................................ 61
3.5 Conclusions .......................................................................................... 63
3.6 References ............................................................................................ 64
4. Dynamic Offset Compensated Instrumentation
Amplifiers .............................................................................................................. 67
4.1 Introduction .......................................................................................... 67
4.1.1 Current-feedback instrumentation amplifiers ............................. 69
4.2 Dynamic offset compensated instrumentation amplifiers .................... 74
4.2.1 Chopper instrumentation amplifier ............................................. 75
4.2.2 Auto-zeroed instrumentation amplifier ....................................... 76
4.2.3 Ping-pong instrumentation amplifier .......................................... 78
4.2.4 Ping-pong-pang instrumentation amplifier ................................. 78
4.2.5 Offset-stabilized instrumentation amplifiers ............................... 79
4.2.6 Chopper offset-stabilized chopper instrumentation amplifier ..... 82
4.3 Conclusions .......................................................................................... 82
4.4 References ............................................................................................82
5. Realizations of Operational Amplifiers ........................ 85
5.1 Introduction .......................................................................................... 85
5.2 Chopper offset-stabilized operational amplifier ................................... 86
5.2.1 Topology ...................................................................................... 86
5.2.2 Circuits ........................................................................................ 91
5.2.3 Measurement results .................................................................... 98
5.3 Chopper and auto-zero offset-stabilized operational amplifier .......... 104
5.3.1 Topology .................................................................................... 104
5.3.2 Circuits ...................................................................................... 107
5.3.3 Measurement results .................................................................. 112
5.4 Conclusions ........................................................................................ 115
5.5 References .......................................................................................... 116
6. Realizations of Instrumentation Amplifiers ............ 117
6.1 Introduction ........................................................................................ 117
6.2 Low-offset indirect current-feedback instrumentation amplifier ....... 118
6.2.1 Introduction ............................................................................... 118
6.2.2 Topology .................................................................................... 118
6.2.3 Circuits ...................................................................................... 122
6.2.4 Measurement results .................................................................. 124
6.3 High-side current-sense amplifier ...................................................... 129
6.3.1 Current-sensing .......................................................................... 129
6.3.2 Topology .................................................................................... 133
6.3.3 Circuits ...................................................................................... 138
6.3.4 Measurement results .................................................................. 143
6.4 Conclusions ........................................................................................ 147
6.5 References .......................................................................................... 149
7. Conclusions and Future Directions ................................ 151
7.1 Conclusions ........................................................................................ 151
7.2 Future directions ................................................................................. 151
7.3 References .......................................................................................... 153
发表于 2009-7-2 01:28:17 | 显示全部楼层
发表于 2009-7-2 09:31:50 | 显示全部楼层
thanks for your sharing
发表于 2009-7-2 09:33:36 | 显示全部楼层
:victory:
发表于 2009-7-2 10:15:50 | 显示全部楼层
thanks for your information.
发表于 2009-7-2 10:54:09 | 显示全部楼层
谢谢楼主分享
发表于 2009-7-2 11:37:09 | 显示全部楼层
good new book ..........
发表于 2009-7-2 12:17:11 | 显示全部楼层
good book, collected
GMT+8, 2025-12-30 11:38 , Processed in 0.025952 second(s), 6 queries , Gzip On, Redis On.
