查看: 11100|回复: 13
[Help!]Cadence AMS仿真PLL问题.
发表于 2009-4-20 22:39:24 | 显示全部楼层 |阅读模式
我用tsmc13rf PDK (v1.2 ?)做的PLL,在ncelab过程中遇到了如下问题(见log):电路中的nmos1v, pmos1v都能过,但是rfnmos1v, rfpmos1v都过不了,我对比发现rf器件缺少ams view,而其他能过的器件都有ams view。我尝试了一下用symbol editor为rf器件创建名为ams的view(因为库中自有的ams view 和symbol view看起来内容一样),但是问题仍没有解决,log报告的错误是一样的。
  诚请指点一下如何解决这个问题?(我现在暂无权限去下载最新的PDK,所以只好想其他办法解决)
  非常感谢!!!
ncelab: 05.81-p002: (c) Copyright 1995-2006 Cadence Design Systems, Inc.
TOOL:    ncelab    05.81-p002: Started on Apr 20, 2009 at 21:32:57 CST
ncelab
    -cds_implicit_tmpdir /home/vikinglan/pll_tsmc013/simulation/PLLtop_tb/ams/config/netlist/ihnl
    -propsPath /home/vikinglan/pll_tsmc013/myPLLThesis/PLLtop_tb/config/prop.cfg
    -timescale 1ns/1ns
    -discipline logic
    -delay_mode None
    -novitalaccl
    -access +r
    -errorMax 50
    -messages
    -status
    -nowarn DLNOHV
    -cdslib /home/vikinglan/pll_tsmc013/cds.lib
    -noparamerr
    -use5x4vhdl
    -update
    -amspartinfo /home/vikinglan/pll_tsmc013/simulation/PLLtop_tb/ams/config/psf/partition.info
    -modelpath /eda/techlib/tsmc13rf/models/tsmc13rf.scs
    -work myPLLThesis
    myPLLThesis.PLLtop_tb:config
    connectLib.ConnRules_12V_full_fast:connect
    myPLLThesis.cds_globalsLLtop_tb_config
    -logfile /home/vikinglan/pll_tsmc013/simulation/PLLtop_tb/ams/config/psf/ncelab.log
    Elaborating the design hierarchy:
ncelab: *W,CUNOUN: Cannot find any unit under tsmc13rf.rfpmos1v:symbol in the design libraries.
ncelab: *E,CUCFUN: instance 'M5' of the unit 'rfpmos1v' is unresolved in 'myPLLThesis.VCO_16bands:schematic'.
ncelab: *E,CUCFUN: instance 'M4' of the unit 'rfpmos1v' is unresolved in 'myPLLThesis.VCO_16bands:schematic'.
ncelab: *W,CUNOUN: Cannot find any unit under tsmc13rf.rfnmos1v:symbol in the design libraries.
ncelab: *E,CUCFUN: instance 'M1' of the unit 'rfnmos1v' is unresolved in 'myPLLThesis.VCO_16bands:schematic'.
ncelab: *E,CUCFUN: instance 'M0' of the unit 'rfnmos1v' is unresolved in 'myPLLThesis.VCO_16bands:schematic'.
ncelab: Memory Usage - 14.4M program + 75.8M data = 90.3M total
ncelab: CPU Usage - 0.1s system + 1.1s user = 1.2s total (1.2s, 100.0% cpu)
TOOL:    ncelab    05.81-p002: Exiting on Apr 20, 2009 at 21:32:58 CST  (total: 00:00:01)
ps:因为PLL中有两个数字模块,而我现有的tsmc13logic库又没有ASIC cell的电路级netlist文件,所以没办法只好做混合信号仿真。唉~~郁闷!
 楼主| 发表于 2009-4-21 11:46:28 | 显示全部楼层
从EDAboard上找到了解决方法
CIW->Conversion Tool Box->AMS simInfo from Spectre
发表于 2009-12-30 22:06:28 | 显示全部楼层
能说的详细点吗?兄弟?我也遇到了与你相类似的问题
AMS仿真能用4端口的MOS管吗??为什么我用4端口的MOS管的时候compile的时候会报错呢?改成3端口的MOS管之后,却又通过了!~~
你知道问题的原因吗??先谢谢了!~
发表于 2010-1-4 11:08:04 | 显示全部楼层
XUEXI学习
 楼主| 发表于 2010-1-12 00:19:36 | 显示全部楼层
我也不是很清楚
大概是需要AMS格式的View吧
你google吧,我当时也是google出来的
3# datone520
发表于 2010-2-24 17:19:08 | 显示全部楼层
可以解决,谢谢
发表于 2010-6-23 14:15:13 | 显示全部楼层
学习下
发表于 2010-7-5 19:59:00 | 显示全部楼层
vikinglan ,能跟您交流下ams仿真的问题吗?我的QQ:414136726
邮箱:lyh20041016@yahoo.com.cn
等候您的回复~
发表于 2010-7-21 15:56:30 | 显示全部楼层
vikinglan前辈, 我正在学习ams仿真。我可以请教你吗? 我的QQ:46943487
等候您的回复
发表于 2010-7-21 18:39:55 | 显示全部楼层
学习了
GMT+8, 2025-9-18 21:11 , Processed in 0.017327 second(s), 3 queries , Gzip On, Redis On.
