查看: 18046|回复: 29
DC-DC中regulator的功率管选择,求助 ADI的面试题
发表于 2009-4-18 00:01:35 | 显示全部楼层 |阅读模式
小弟想问大家一个问题
在dcdc中一般都有个Regulator,那么是选择nmos还是pmos比较好呢?
这是ADI一道很普通的面试题,希望大家多多指教
 楼主| 发表于 2009-4-19 22:00:25 | 显示全部楼层
没有人知道????
发表于 2009-4-19 22:04:52 | 显示全部楼层
cmos工艺用pmos
发表于 2009-4-20 08:45:44 | 显示全部楼层
原帖由 icsb 于 2009-4-18 00:01 发表
小弟想问大家一个问题
要折中考虑这个问题吧,根据你的实际应用和工艺情况再决定选NMOS还是PMOS比较好……
如果从功耗方面考虑需要从面积  电源电压  寄生电容……
 楼主| 发表于 2009-4-24 23:20:00 | 显示全部楼层
我觉得这样回答比较好
Regulator的主要目的是提供一个恒定的电压源,所以希望输出电阻比较小,这样考虑的话当然是选NMOS
如果从电压考虑,用PMOS所需的电源电压比较低,如果不是高压的DC-DC,还是选PMOS比较好
发表于 2009-4-25 06:47:45 | 显示全部楼层
原帖由 icsb 于 2009-4-24 23:20 发表
我觉得这样回答比较好
You are completely wrong. In term of close loop, the output impedance is mainly determined by loop gain regardless NMOS or PMOS output stage.
Of course if your same loop gain, NMOS output have lower impedance but frequency compensation more complex to keep same loop gain than PMOS type.
NMOS can also work for low power supply voltage although PMOS is more convenient especially for higher efficiency power stage.
Generally, both PMOS and NMOS used a lot in different type DC-DC regulator(converter) and LDOs. It must be tradeoff among power efficiency, current driving ability, stability, frequency compensation, PSRR, process, external component etc.
发表于 2009-4-25 08:38:48 | 显示全部楼层
在其他帖子里已经详细比较过
PNP NPN 达林顿 NMOS PMOS 了,找找吧
发表于 2009-4-25 10:27:37 | 显示全部楼层
在其他帖子里已经详细比较过
 楼主| 发表于 2009-4-25 16:33:03 | 显示全部楼层
原帖由 prof3 于 2009-4-25 06:47 发表
Of course if your same loop gain, NMOS output have lo ...
so can you describe it detaily?So as when we care PSRR,wo choose PMOS(or NMOS)
when we care die size we choose NMOS?
ALSO ,why NMOS frequency compention is harder than PMOS?thanks
发表于 2009-7-2 12:19:34 | 显示全部楼层
484
GMT+8, 2025-12-22 16:31 , Processed in 0.021345 second(s), 6 queries , Gzip On, Redis On.
