楼主: icsb
DC-DC中regulator的功率管选择,求助 ADI的面试题
发表于 2009-7-2 12:56:29 | 显示全部楼层
用Nmos管电源抑制比不好,增益也低
现在一般用PMOS
发表于 2009-7-3 13:11:57 | 显示全部楼层
现在要求电源电压和输出电压相差不大,以提高效率
所以根本不会考虑用NMOS管
发表于 2009-7-3 21:16:50 | 显示全部楼层
原帖由 icsb 于 2009-4-25 16:33 发表
so can you describe it detaily?So as when we care PSRR,wo choose PMOS(or NMOS)
when we care die size we choose NMOS?
ALSO ,why NMOS frequency compention is harder than PMOS?thanks
what u said is not right
the output impedance are the same, both ro/gmro/gmro~1/gm/gmro
regarding the PSR, PMOS have better PSR at low freq, while NMOS have better PSR at high freq
发表于 2009-7-3 22:38:15 | 显示全部楼层
97 good!!
发表于 2009-7-5 13:22:16 | 显示全部楼层
只要学得好工作都好找
发表于 2009-8-26 20:15:48 | 显示全部楼层
收益非浅,
发表于 2009-9-8 20:08:18 | 显示全部楼层
恼火啊。。。。。。。。。。。
发表于 2010-2-14 11:02:53 | 显示全部楼层
收益非浅,
发表于 2010-2-14 17:45:35 | 显示全部楼层
为啥dcdc里面有个regulator...这个regulator干啥用的?
发表于 2010-2-24 13:56:53 | 显示全部楼层
肯定是PMOS,传递高电平没有Vth的损耗,转换效率会高!
GMT+8, 2025-12-23 11:51 , Processed in 0.017967 second(s), 3 queries , Gzip On, Redis On.
