查看: 29802|回复: 70
250MHZ 10bit Pipeline ADC 的初步结果
发表于 2009-4-7 19:22:31 | 显示全部楼层 |阅读模式
终于把ADC的电路基本做完了
跑了些simulation,结果还行
不过原来目标的20mA现在已经大大超标了,都到34mA了,还好boss不究
由于没有经验,没能进行充分完整的估计
现在回顾起来,20mA做出来250MHz 10bit ADC 还是非常困难的
首先,原来设想的每个stage scaling down 并不是那么容易的
其次,一些bias和buffer也会消耗不小的电流
如果要做到20mA以内,两个stage间opamp复用是一个好方法,不过这也会引起许多其他问题
Date: 2009-4-7
ADC simulation result,2048 point DFT
CLK = 125MHz
CLK = 166MHz
CLK = 250MHz
Input signal
~10MHz
SFDR=78.8dB
SNDR=61.83dB
thd=0.081%
THD=0.0196%
       =-74.15dB
SFDR=79.27dB
SNDR=61.66dB
thd=0.0826%
THD=0.0254%
       =-71.90dB
SFDR=77.4dB
SNDR=61.55dB
thd=0.0837%
THD=0.0288%
       =-70.81dB
Input signal
Nyquist Frequency
1/2 fs
SFDR=79.3dB
SNDR=61.5dB
thd=0.084%
THD=0.0296%
       =-70.57dB
SFDR=75.8dB
SNDR=61.3dB
thd=0.086%
THD=0.0349%
       =-69.14dB
SFDR=70.4dB
SNDR=60.72dB
thd=0.092%
THD=0.0478%
       =-66.41dB
Note: The thd is calculated by thd function in Spectre calculator. The function calculates the total harmonic spectrum energy expect DC component. Quantization noise and actual Total Harmonic Distortion are included in thd results.
The Quantization Noise of Ideal 10 bit ADC is 0.0786%(-62.09dB)
The actual Total Harmonic Distortion can be calculated as formula:
THD=sqrt(thd^2-0.0786%^2)
[ 本帖最后由 fuyibin 于 2009-4-8 08:57 编辑 ]
发表于 2009-4-7 21:00:06 | 显示全部楼层
相当NB了,已经
发表于 2009-4-7 21:17:27 | 显示全部楼层
菜鸟问lz一个问题
lz设计的mdac运放的单位增益带宽是多少啊
 楼主| 发表于 2009-4-8 08:56:30 | 显示全部楼层
发表于 2009-4-8 08:58:54 | 显示全部楼层
reference buffer power included?
Noise is okay?
 楼主| 发表于 2009-4-8 09:24:21 | 显示全部楼层
原帖由 vdslafe 于 2009-4-8 08:58 发表
Noise is okay?
bandgap and VREF buffer have been included
All ADC circuits are integrated.
voltage reference settling is ok
Noise? reference thermal noise?
How can the thermal noise be included in tran simulation?
Spectre simulator has this function?
发表于 2009-4-8 11:26:51 | 显示全部楼层
reference buffer 用了off-chip cap 没?
noise 只能手算,根据noise sim 结果
你也可以用Pnoise
发表于 2009-4-8 12:23:44 | 显示全部楼层
对你的sndr持保留意见,相当接近10bit 的理想snr了。
是不是计算上有问题?
Maxim 的max1124, 180Mhz input, sndr = 56dB.
发表于 2009-4-8 12:30:32 | 显示全部楼层
楼上的前辈,他是simulation 结果啊,没有thermal noise. 如果linearity 很好,是可以做到 simulation 结果 是60db SNDR
发表于 2009-4-8 12:33:53 | 显示全部楼层
原帖由 vdslafe 于 2009-4-8 12:30 发表
simulaiton 应该有thermal noise的吧。怎么会没有?
GMT+8, 2025-12-24 20:27 , Processed in 0.031404 second(s), 5 queries , Gzip On, Redis On.
