 Discrete-Time Signal Processing - 2ed 扫面版
从事通信相关的数字信号处理设计工作,必备的基础资料。本人在阅读时加入了的一些注释和标记,希望能有助于您的理解。
26 of 27 people found the following review helpful:
5.0 out of 5 stars Six star book on Digital Signal Processing, February 28, 2006 By calvinnme "Texan refugee" (Fredericksburg, Va) - See all my reviews
(TOP 10 REVIEWER)
This review is from: Discrete-Time Signal Processing (2nd Edition) (Prentice-Hall Signal Processing Series) (Hardcover)
This is the outstanding 2nd edition of Oppenheim's classic DSP book, which for over two decades was the only real choice for a textbook on the subject. That was too bad, since the first edition was probably the worst thing I have ever seen in print - terse, incomprehensible, and with only a few awful and poorly illustrated examples. When I decided to take a refresher course in DSP, I was horrified to see our class would be using the second edition of that horrendous text. What I found instead was a completely rehabilitated textbook! This is not a beginner's DSP textbook by any stretch of the imagination, but absolutely everything is explained and there are plenty of well worked out examples. The end-of-chapter problems are broken down into simple, intermediate, and advanced problems with quite a few mind-puzzlers in the advanced section. Plus, the answers to the first 20 problems in every chapter are in the back of the book.
There is really nothing unique about the book's format. What does makes the book unique is the density and amount of material included. Just about every page is packed with well-explained important information. I highly recommend this book to anyone who has had a prior semester of an upper-level undergraduate class in Signals and Systems and wants to study DSP. An accompanying book that you might find helpful is "Understanding Digital Signal Processing" by Lyons. That book is good for getting an intuitive feel for DSP. Another book that will help you with some of the earlier concepts in this book (linear systems, DTFT, Z-transform, DFT, basic filter design) and some of the direct computations involved is "Schaum's Outline of Digital Signal Processing". Amazon does not show the table of contents, so I do that here:
1. Introduction.
2. Discrete-Time Signals and Systems.
Introduction. Discrete-time Signals: Sequences. Discrete-time Systems. Linear Time-Invariant Systems. Properties of Linear Time-Invariant Systems. Linear Constant-Coefficient Difference Equations. Frequency-Domain Representation of Discrete-Time Signals and Systems. Representation of Sequence by Fourier Transforms. Symmetry Properties of the Fourier Transform. Fourier Transform Theorems. Discrete-Time Random Signals. Summary.
3. The z-Transform.
Introduction. The z-Transform. Properties of the Region of Convergence for the z-Transform. The Inverse z-Transform. z-Transform Properties. Summary.
4. Sampling of Continuous-Time Signals.
Introduction. Periodic Sampling. Frequency-Domain Representation of Sampling. Reconstruction of a Bandlimited Signal from its Samples. Discrete-Time Processing of Continuous-Time Signals. Continuous-Time Processing of Discrete-Time Signals. Changing the Sampling Rate Using Discrete-Time Processing. Practical Considerations. Oversampling and Noise Shaping. Summary.
5. Transform Analysis of Linear Time-Invariant Systems.
Introduction. The Frequency Response of LTI Systems. System Functions for Systems Characterized by Linearity. Frequency Response for Rational System Functions. Relationship Between Magnitude and Phase. All-Pass Systems. Minimum-Phase Systems. Linear Systems with Generalized Linear Phase. Summary.
6. Structures for Discrete-Time Systems.
Introduction. Block Diagram Representation of Linear Constant-Coefficient Difference Equations. Signal Flow Graph Representation of Linear Constant-Coefficient Difference Equations. Basic Structures for IIR Systems. Transposed Forms. Basic Network Structures for FIR Systems. Overview of Finite-Precision Numerical Effects. The Effects of Coefficient Quantization. Effects of Roundoff Noise in Digital Filters. Zero-Input Limit Cycles in Fixed-Point Realizations of IIR Digital Filters. Summary.
7. Filter Design Techniques.
Introduction. Design of Discrete-Time IIR Filters from Continuous-Time Filters. Design of FIR Filters by Windowing. Examples of FIR Filter Design by the Kaiser Window Method. Optimum Approximations of FIR Filters. Examples of FIR Equiripple Approximation. Comments on IIR and FIR Digital Filters. Summary.
8. The Discrete Fourier Transform.
Introduction. Representation of Periodic Sequences: the Discrete Fourier Series. Summary of Properties of the DFS Representation of Periodic Sequences. The Fourier Transform of Periodic Signals. Sampling the Fourier Transform. Fourier Representation of Finite-Duration Sequences: The Discrete-Fourier Transform. Properties of the Discrete Fourier Transform. Summary of Properties of the Discrete Fourier Transform. Linear Convolution Using the Discrete Fourier Transform. The Discrete Cosine Transform (DCT). Summary.
9. Computation of the Discrete Fourier Transform.
Introduction. Efficient Computation of the Discrete Fourier Transform. The Goertzel Algorithm Decimation-in-Time FFT Algorithms. Decimation-in-Frequency FFT Algorithms. Practical Considerations Implementation of the DFT Using Convolution. Summary.
10. Fourier Analysis of Signals Using the Discrete Fourier Transform.
Introduction. Fourier Analysis of Signals Using the DFT. DFT Analysis of Sinusoidal Signals. The Time-Dependent Fourier Transform. Block Convolution Using the Time-Dependent Fourier Transform. Fourier Analysis of Nonstationary Signals. Fourier Analysis of Stationary Random Signals: the Periodogram. Spectrum Analysis of Random Signals Using Estimates of the Autocorrelation Sequence. Summary.
11. Discrete Hilbert Transforms.
Introduction. Real and Imaginary Part Sufficiency of the Fourier Transform for Causal Sequences. Sufficiency Theorems for Finite-Length Sequences. Relationships Between Magnitude and Phase. Hilbert Transform Relations for Complex Sequences. Summary.
Discrete-Time Signal Processing - 2ed ().part1.rar
(4.77 MB , 下载次数:
441 )
Discrete-Time Signal Processing - 2ed ().part2.rar
(4.4 MB , 下载次数:
416 )
