发表于 2009-3-28 02:54:54
显示全部楼层
1. Off-chip CAP solution
Advantage is low power, low nosie. But please remember since in this case, dominant pole is at OUTPUT, your buffer design must be careful. Your output impedance must be high, and all the internal stage impedance should be low to keep non-dorminat pole at high frequency. Otherwise there still stability issue. You can also refer LDO type design for this buffer. In the end, don't forget your ESD resistor may harm your performance
2. On-Chip Solution
Advantage is saving one PIN count. But as you may know, power is very consuming especially in hgih speed buffer. Also noise is another headache. There are many on-chip solution depending on your speed and resolution. I assume your resolution is 10bit and speed <200MSPS, OPEN LOOP solution is great help and simple and many many people like because no stability issue, simple circuti structure and more, power consumption is reasonable.
3. Final Suggestion
Remember, reference buffer design is more difficult and important even than SHA. Don't take it for granted.
Hopefully it helps you. |
