查看: 2582|回复: 5
SSC removal
发表于 2009-3-23 15:57:05 | 显示全部楼层 |阅读模式
Hi, does anyone know how to demodulate the SSC effect embedded in the input clock to PLL? In PCIE1.1 specification, the input reference clock is modulated to be +/-300ppm due to SSC to avoid any EMI concern. If we ddin't de-modulate it properly, what will happen to our PLL?
发表于 2009-3-24 07:45:53 | 显示全部楼层
Don't need demoulation. Actually, I don't think SSC is needed for PCIE 1.0.
 楼主| 发表于 2009-3-25 14:26:34 | 显示全部楼层
thanks for pointing out. SSC feature may or may not be implemented due to platform level timing issue according to PCIE CEM 1.1 spec. If the reference clock supports spread spectrum clocking, any design challenge or concern applied to PLL to minimize the jitter?
发表于 2009-3-26 08:23:05 | 显示全部楼层
Not really, the SSC is strictly well-defined. I remember it is 0~-5000ppm.  Nothing specially except your PLL Loop can accomendate the headroom for the Vctrl.
 楼主| 发表于 2009-3-29 00:58:03 | 显示全部楼层
how can i setup the simulation to test out if my PLL design can accommodate the SSC effect in reference input clock?
 楼主| 发表于 2009-3-30 10:55:07 | 显示全部楼层
Or, what is the design criteria of the loop filter to reserve the headroom for Vctrl so that it can take in this reference clock with SSC effect? If SSC is about -5000ppm, is it similar to 0.5% frequency offset if reference clock is running at 100MHz
GMT+8, 2025-11-10 16:40 , Processed in 0.018498 second(s), 3 queries , Gzip On, Redis On.
