我刚解决了一个问题,就是将encounter里的gds能够“完全”导入virtuoso能够显示.先给大家分享一下,希望能够给有相同难题的同仁带来一些帮助:
开始的时候encounter导GDS出来的时候有个streamout.map这个文件我以为是输出文件就没有管它,后来发现导入virtuoso里的metal层和via这些都不对。经过请教才发现encounter导GDS时的streamout.map文件是输入文件,而不是输出文件,所以我就按照virtuoso里的tf文件的定义改了层位置,再从encounter里导出GDS,这样在virtuoso里就可以发现metal层和via都是正确的。
我本以为这样就可以了,但是我在做DRC的时候确报错了。
错误信息如下:
Rule File Pathname: /home/cwg/cds/_SmicDR4P6P_cal018_mixlog_sali_p1mt6_1833.drc_
Minimum space between two NW regions with the same potential is 0.60um
Merge if space is less than 0.6um
Minimum width of an M2 region is 0.28um
Minimum space between two M2 regions is 0.28um
Minimum width of an M3 region is 0.28um
Minimum space between two M3 regions is 0.28um
Minimum area of a M3 region is 0.20um
Minimum width of an M4 region is 0.28um
Minimum width of an M5 region is 0.28um
Minimum space between two M5 regions is 0.28um
Minimum space between two V1 is 0.26um
Minimum space between two V2 is 0.26um
Minimum space between two V3 is 0.26um
Minimum space between two V4 is 0.26um
Minimum/maximum size of a VT is 0.36um
Minimum space between two VT is 0.35um
从错误信息来看,encounter在自动布线时via to via,metal to metal 和via to metal的间距都没有考虑,所以在DRC的时候就报了很多这样的错误。
请问是不是LEF文件(Rev 2.0, Date 02-08-2003 and Document TD-L018-BL-2001 Rev 2R)和DRC文件(Date: 2007/08/06)的版本不匹配?还是我在encounter里导出GDS前修改的streamout.map有问题呢?还是有别的原因呢?
下面是LEF文件的版本信息(1),DRC的版本信息(2),tf文件在层次上的定义(3)和我在encounter streamout时修改后的streamout.map文件(4):
(1):LEF版本信息
# TECH LIB NAME: smic18
# TECH FILE NAME: techfile.cds
# RC values have been extracted from SMIC's Interconnect Capacitance
# Table, Rev 2.0, Date 02-08-2003 and Document TD-L018-BL-2001 Rev 2R
# Resistance and Capacitance Values
# The LEF technology files included in this directory contain
# resistance and capacitance (RC) values for the purpose of timing
# driven place & route. Please note that the RC values contained in
# this tech file were created using the worst case interconnect models
# from the foundry and assume a full metal route at every grid location
# on every metal layer, so the values are intentionally very
# conservative. It is assumed that this technology file will be used
# only as a starting point for creating initial timing driven place &
# route runs during the development of your own more accurate RC
# values, tailored to your specific place & route environment. AS A
# RESULT, TIMING NUMBERS DERIVED FROM THESE RC VALUES MAY BE
# SIGNIFICANTLY SLOWER THAN REALITY.
# The RC values used in the LEF technology file are to be used only
# for timing driven place & route. Due to accuracy limitations,
# please do not attempt to use this file for chip-level RC extraction
# in conjunction with your sign-off timing simulations. For chip-level
# extraction, please use a dedicated extraction tool such as HyperExtract,
# starRC or Simplex, etc.
# $Id: smic18_6lm.lef,v 1.4 2003-03-10 18:30:04-08 wching Exp $
VERSION 5.2 ;
(2):DRC的版本信息:
//$Author: Karen Kang
//$Revision: 1.1
//$Date: 2007/08/06 01:03:59 $
//| 0.18um 1P6M Calibre DRC rule file for |
//| SMIC: 0.18um LOGIC 1P6M Salicide 1.8V/3.3V Design Rule |
//| Doc. No.: TD-LO18-DR-2001 Rev.: 4 T |
//| SMIC: 0.18um Mixed-Signal 1P6M Salicide 1.8V/3.3V Design Rule |
//| Doc. No.: TD-MM18-DR-2001 Rev.: 6 P |
//| SMIC DSD Technologies |
(3):tf文件在层次上的定义
( M1 61 M1 )
( M2 62 M2 )
( M3 63 M3 )
( M4 64 M4 )
( M5 65 M5 )
( M6 66 M6 )
( V1 70 V1 )
( V2 71 V2 )
( V3 72 V3 )
( V4 73 V4 )
( V5 74 V5 )
( OPCBA 100 OPCBA )
( OPCBP 101 OPCBP )
( OPCBM 102 OPCBM )
( M1TXT 141 M1TXT )
( M2TXT 142 M2TXT )
( M3TXT 143 M3TXT )
( M4TXT 144 M4TXT )
( M5TXT 145 M5TXT )
( M6TXT 146 M6TXT )
(4):在encounter streamout时修改后的streamout.map文件
METAL1 NET 61 0
METAL1 SPNET 61 0
METAL1 PIN 61 0
METAL1 LEFPIN 61 0
METAL1 FILL 61 0
METAL1 VIA 61 0
METAL1 VIAFILL 61 0
METAL1 LEFOBS 61 0
NAME METAL1/NET 141 0
NAME METAL1/SPNET 141 0
NAME METAL1/PIN 141 0
NAME METAL1/LEFPIN 141 0
VIA12 FILL 70 0
VIA12 VIA 70 0
VIA12 VIAFILL 70 0
METAL2 NET 62 0
METAL2 SPNET 62 0
METAL2 PIN 62 0
METAL2 LEFPIN 62 0
METAL2 FILL 62 0
METAL2 VIA 62 0
METAL2 VIAFILL 62 0
METAL2 LEFOBS 62 0
NAME METAL2/NET 142 0
NAME METAL2/SPNET 142 0
NAME METAL2/PIN 142 0
NAME METAL2/LEFPIN 142 0
VIA23 FILL 71 0
VIA23 VIA 71 0
VIA23 VIAFILL 71 0
METAL3 NET 63 0
METAL3 SPNET 63 0
METAL3 PIN 63 0
METAL3 LEFPIN 63 0
METAL3 FILL 63 0
METAL3 VIA 63 0
METAL3 VIAFILL 63 0
METAL3 LEFOBS 63 0
NAME METAL3/NET 143 0
NAME METAL3/SPNET 143 0
NAME METAL3/PIN 143 0
NAME METAL3/LEFPIN 143 0
VIA34 FILL 72 0
VIA34 VIA 72 0
VIA34 VIAFILL 72 0
METAL4 NET 64 0
METAL4 SPNET 64 0
METAL4 PIN 64 0
METAL4 LEFPIN 64 0
METAL4 FILL 64 0
METAL4 VIA 64 0
METAL4 VIAFILL 64 0
METAL4 LEFOBS 64 0
NAME METAL4/NET 144 0
NAME METAL4/SPNET 144 0
NAME METAL4/PIN 144 0
NAME METAL4/LEFPIN 144 0
VIA45 FILL 73 0
VIA45 VIA 73 0
VIA45 VIAFILL 73 0
METAL5 NET 65 0
METAL5 SPNET 65 0
METAL5 PIN 65 0
METAL5 LEFPIN 65 0
METAL5 FILL 65 0
METAL5 VIA 65 0
METAL5 VIAFILL 65 0
METAL5 LEFOBS 65 0
NAME METAL5/NET 145 0
NAME METAL5/SPNET 145 0
NAME METAL5/PIN 145 0
NAME METAL5/LEFPIN 145 0
VIA56 FILL 74 0
VIA56 VIA 74 0
VIA56 VIAFILL 74 0
METAL6 NET 66 0
METAL6 SPNET 66 0
METAL6 PIN 66 0
METAL6 LEFPIN 66 0
METAL6 FILL 66 0
METAL6 VIA 66 0
METAL6 VIAFILL 66 0
METAL6 LEFOBS 66 0
NAME METAL6/NET 146 0
NAME METAL6/SPNET 146 0
NAME METAL6/PIN 146 0
NAME METAL6/LEFPIN 146 0
NAME COMP 101 0
COMP ALL 102 0
DIEAREA ALL 112 0
大家看看究竟是什么原因呢?
是map文件修改后又问题呢?还是encounter里用的lef文件和virtuoso里用的tf文件版本不匹配(或者说是lef文件rule不全)呢? |
