查看: 1761|回复: 1
可重触发数据寻峰VHDL代码(原)
发表于 2009-1-9 10:19:16 | 显示全部楼层 |阅读模式
-- An example of data peak finder
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
---- Uncomment the following library declaration if instantiating
---- any Xilinx primitives in this code.
--library UNISIM;
--use UNISIM.VComponents.all;
entity peakfinder is
port(    clk        : in std_logic;
        timesig    : in std_logic;
        din        : in std_logic_vector(15 downto 0);
        dout        : out std_logic_vector(15 downto 0)
end peakfinder;
architecture Behavioral of peakfinder is
signal datain_1    : std_logic_vector(15 downto 0):="0000000000000000";
signal datain_2    : std_logic_vector(15 downto 0):="0000000000000000";
signal datain_3    : std_logic_vector(15 downto 0):="0000000000000000";
signal datain_4    : std_logic_vector(15 downto 0):="0000000000000000";
signal datain_5    : std_logic_vector(15 downto 0):="0000000000000000";
signal datain_6    : std_logic_vector(15 downto 0):="0000000000000000";
signal datain_7    : std_logic_vector(15 downto 0):="0000000000000000";
signal datain_8    : std_logic_vector(15 downto 0):="0000000000000000";
signal datain_9    : std_logic_vector(15 downto 0):="0000000000000000";
signal datain_a    : std_logic_vector(15 downto 0):="0000000000000000";
signal datain_b    : std_logic_vector(15 downto 0):="0000000000000000";
signal datain_c    : std_logic_vector(15 downto 0):="0000000000000000";
signal datasum_0    : std_logic_vector(15 downto 0):="0000000000000000";
signal datasum_1    : std_logic_vector(15 downto 0):="0000000000000000";
signal datasum_2    : std_logic_vector(15 downto 0):="0000000000000000";
signal datasum_3    : std_logic_vector(15 downto 0):="0000000000000000";
signal datasum_4    : std_logic_vector(15 downto 0):="0000000000000000";
signal datasum_5    : std_logic_vector(15 downto 0):="0000000000000000";
signal datamax        : std_logic_vector(15 downto 0):="0000000000000000";
signal datamaxposition    : std_logic_vector(4 downto 0):="00000";
signal peakfindcnt : std_logic_vector(4 downto 0):="00000";
signal Trigger        : std_logic:='0';
signal PreReTrig    : std_logic:='0';
signal ReTrig        : std_logic:='0';
begin
-- 流水线赋值
process (clk)
begin
    if clk'event and clk = '1' then
        datain_1 <= din;
        datain_2 <= datain_1;
        datain_3 <= datain_2;
        datain_4 <= datain_3;
        datain_5 <= datain_4;
        datain_6 <= datain_5;
        datain_7 <= datain_6;
        datain_8 <= datain_7;
        datain_9 <= datain_8;
        datain_a <= datain_9;
        datain_b <= datain_a;
        datain_c <= datain_b;
    end if;
end process;
-- 流水线求和
process (clk)
begin
        datasum_0 <= datain_1 + datain_2 + datain_3 + datain_4 + datain_5 + datain_6 + datain_7 + datain_8 + datain_9 + datain_a + datain_b + datain_c ;
        datasum_1 <= datasum_0;
        datasum_2 <= datasum_1;
        datasum_3 <= datasum_2;
        datasum_4 <= datasum_3;
        datasum_5 <= datasum_4;
    end if;
end process;
-- 数据寻峰    >>>>>>>>>>>>>>>>>>
-- get the trigger signal, then count from zero;
process(clk,timesig)
begin
        if (timesig = '1' and peakfindcnt = "00000") then
            Trigger <= '1';
        else
            Trigger <= '0';
        end if;
    end if;
end process;
-- get the retrigger siganl, then count from zero again;
begin
        if (timesig = '0' and peakfindcnt > "00000" and peakfindcnt < "10000") then
            PreReTrig <= '1';
        elsif (timesig = '1' and  PreReTrig = '1') then
            ReTrig <= '1';
            PreReTrig <= '0';
        else --if peakfindcnt = "10000" then
            ReTrig <= '0';
            PreReTrig <= '0';
        end if;
    end if;
end process;
-- trigger count
process (clk,timesig)
begin
        if Trigger = '1' or ReTrig = '1'    then
            peakfindcnt <= "00001";
        elsif peakfindcnt > "00000" and peakfindcnt < "10000"    then
            peakfindcnt <= peakfindcnt + 1;
        elsif timesig = '0' and peakfindcnt = "10000" then
            peakfindcnt <= "00000";
        end if;
    end if;
end process;
process (clk,peakfindcnt,din,datamax)
begin
        if peakfindcnt = "00000" then
            datamax <= "0000000000000000";
            datamaxposition <= "00000";
            if din > datamax then
                datamax <= din;
                datamaxposition <= peakfindcnt;
            end if;
        end if;
    end if;
end process;
begin
            if datamaxposition = "00101" then
                dout <= datasum_5;
            elsif datamaxposition = "00110" then
                dout <= datasum_4;
            elsif datamaxposition = "00111" then
                dout <= datasum_3;
            elsif datamaxposition = "01000" then
                dout <= datasum_2;
            elsif datamaxposition = "01001" then
                dout <= datasum_1;
            elsif datamaxposition = "01010" then
                dout <= datasum_0;
            end if;
        else
            dout <= "0000000000000000";
        end if;
    end if;
end process;
end Behavioral;
----------------------Retrigger Timing--------------------------
-- timesig:        __|~~~|__________|~~~~~|_________________________
--    trigger:        __|~|____________________________________________
--    PreReTrig:    ______|~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~|___________
-- ReTrig:        _________________|~|_____________________________
-- Peakcount:    --|1|2|3|4|5|....|1|2|3|4|5|6|.......|16|--------
-----------------------Data Output Timing--------------------------
-- TimeSig: __|~~~~|_______________________________________________
-- Datain : -----------------------------*-------------------------
-- Count    :    ==|0|1|2|3|................................|f|10|
-- DataOut:    ----------------------------------------------|dout|
--    Position:  |<----datamaxposition----->|
-- MaxValue:                                      V
-- range    :      |<--------- 6~10 --------->|<------10~6-----|
头像被屏蔽
发表于 2009-1-9 13:11:13 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
GMT+8, 2025-10-4 04:14 , Processed in 0.015715 second(s), 7 queries , Gzip On, Redis On.
