查看: 8156|回复: 2
新手问综合问题
发表于 2008-12-2 15:33:27 | 显示全部楼层 |阅读模式
Startpoint: b_reg (rising edge-triggered flip-flop clocked by clock)
  Endpoint: U1 (falling edge-triggered data to data check clocked by clock)
  Path Group: clock
  Path Type: max
  Des/Clust/Port     Wire Load Model       Library
  test               05x05                 class
  Point                                    Incr       Path
  clock clock (rise edge)                  0.00       0.00
  clock network delay (ideal)              0.00       0.00
  b_reg/CP (FD1)                           0.00       0.00 r
  b_reg/Q (FD1)                            1.44       1.44 f
  U1/B (MY_ANALOG_CELL)                    0.00       1.44 f
  data arrival time                                   1.44
  a_reg/CP (FD1)                           0.00       0.00 r
  a_reg/Q (FD1)                            1.44       1.44 f
  U1/A (MY_ANALOG_CELL)                    0.00       1.44 f
  data check setup time                    0.60       2.04
  data required time                                  2.04
  data arrival time                                  -1.44
  slack (MET)                                         0.60
  Path Group: clock
  Path Type: max
  test               05x05                 class
  Point                                    Incr       Path
  slack (MET)                                         0.60
综合报告中的r,f应该是rising和falling的意思吧,但是我用到的寄存器都是上升沿出发的啊,为什么会出来falling edge呢?不太明白,刚学综合希望大家帮帮忙啊,谢谢
 楼主| 发表于 2008-12-2 15:36:32 | 显示全部楼层
buhaoyisi,第二条路径贴错了。重贴
  Endpoint: U1 (rising edge-triggered data to data check clocked by clock)
  Path Group: clock
  Path Type: max
  test               05x05                 class
  Point                                    Incr       Path
  b_reg/Q (FD1)                            1.29       1.29 r
  U1/B (MY_ANALOG_CELL)                    0.00       1.29 r
  data arrival time                                   1.29
  a_reg/Q (FD1)                            1.29       1.29 r
  U1/A (MY_ANALOG_CELL)                    0.00       1.29 r
  data check setup time                    0.60       1.89
  data required time                                  1.89
  data arrival time                                  -1.29
  slack (MET)                                         0.60
在这条path中,b_reg是rising的,之前的path中是falling的
 楼主| 发表于 2008-12-2 16:25:11 | 显示全部楼层
没人?自己顶吧
GMT+8, 2025-12-22 06:41 , Processed in 0.019861 second(s), 6 queries , Gzip On, Redis On.
