查看: 2235|回复: 1
请强人帮忙翻译一下 多谢
发表于 2008-11-3 20:45:28 | 显示全部楼层 |阅读模式
Embodiments of the invention provide a device with a die and a substrate having a similar coefficient of thermal expansion to that of the die. The substrate may comprise a silicon base layer. Build up layers may be formed on the side of the base layer further from the die.
发表于 2008-11-3 20:49:32 | 显示全部楼层
6hole you up
GMT+8, 2025-11-30 10:15 , Processed in 0.264782 second(s), 7 queries , Gzip On, Redis On.
