查看: 3280|回复: 7
^Sonnet 14.42 Linux
发表于 2016-4-26 04:07:38 | 显示全部楼层 |阅读模式
Hi everyone,
Could anyone provide some link to Sonnet 14 or 15 for Linux? I am using CentOS 6 64 bits.
I appreaciate your help,
Thanks in advance!
发表于 2016-4-26 08:48:21 | 显示全部楼层
I have it.v15.54 and 16.52 linux.
发表于 2016-4-26 20:04:33 | 显示全部楼层
I have installed sucessfully precracked hfss linux in suse 11.2 64bit server, will upload today
hfss 14 linux program for you.
发表于 2016-4-26 20:13:09 | 显示全部楼层
note, the only type of linux that it  seemed to work on was suse 64 bit all centos and redhat versions would fail install, give suse 11.2 64bit server a go it works easy.
will upload later today hfss 14 linux which works fine
 楼主| 发表于 2016-4-27 22:33:06 | 显示全部楼层
I am looking for sonnet because i can use it together with virtuoso in an easy way. Could someone provide some links please?
Thank you guys in advance
 楼主| 发表于 2016-4-27 22:34:47 | 显示全部楼层
回复 2# medmake
    Hi medmake, could you please upload sonnet 14 or 15 for linux please? I would really appreciate it.
Thank you!
BR
发表于 2016-4-28 18:27:14 | 显示全部楼层
If you look in this forum for hfss 14 linux, you can download it, I will try and upload, its i do not know how to share file from pan baido, if you can tell me how i upload streight away
发表于 2016-7-7 15:24:57 | 显示全部楼层
回复 7# jgfh123fgg234
  i need hfss for linux!     could you upload it?
is it cracked?
GMT+8, 2025-12-25 10:50 , Processed in 0.018863 second(s), 5 queries , Gzip On, Redis On.
