查看: 29473|回复: 134
【McGraw-Hill 1999】Switchmode Power Supply Handbook, 2nd Edition
发表于 2008-9-23 21:41:45 | 显示全部楼层 |阅读模式
[size=120%]Switchmode Power Supply Handbook (McGraw-Hill Handbooks)
By Keith Billings
  • Publisher:   McGraw-Hill Professional
  • Number Of Pages:   450
  • Publication Date:   1999-02-28
  • ISBN-10 / ASIN:   0070067198
  • ISBN-13 / EAN:   9780070067196
  • Binding:   Hardcover
Product Description:
Unarguably the leading hands-on guide in this rapidly expanding area of electronics, Keith Billings' new revision of his Switchmode Power Supply Handbook brings state-of-the-art techniques and developments to engineers at all levels. Offering sound working knowledge of the latest in topologies and clear, step-by-step approaches to component decisions, this Handbook gives power supply designers practical, solutions-oriented design guidance free of unnecessarily complicated mathematical derivations and theory. This thoroughly updated Handbook features many new fully worked examples, as well as numerous nomograms--everything you need to design today's smaller, faster, and cooler systems. Turn to just about any page, and you'll find cutting-edge design expertise on electronic ballast, power factor correction, new thermal management techniques, transformers, chokes, input filters, EMI control, converters, snubber circuits, auxiliary systems, and much more. The most comprehensive book on power supply design available anywhere, Switchmode Power Supply Handbook is the industry standard, now fully updated for the 21st century.
Summary: Exelente reference book.
Rating: 5
I always was thinking in buy or not this book becasue of some other customer opinions, so i took the risk and bought it.
Great book, a lot of information regrading tips for inductor, transformer, softstart, step-down and flyback, it has many pages about everything abouth SMPS and Linear Supply.
If you want a book for reference on SMPS, buy this one, it has many examples, calculations, etc, and is a pleasure read this book.
You will receive what you pay.
Saludos...
Summary: Useful and enjoyable
Rating: 5
I bought this book as a complement to Abraham I. Pressman's Switching Power Supply Design.
These two books are very similar, but do not overlap all that much. I am glad to have them both.
This book can be used as a textbook or as a reference. It is so well organised you can find what you need very fast through the table of contents. Concepts are supported by schematics and graphs.
I am using this book to learn analog design and to learn to build my own switching power supplies.
Summary: A good book for its purpose
Rating: 4
I recently purchased both this book, and Switching Power Supply Design by Abraham I. Pressman. I had cursory knowledge of SMPS from datasheets and appnotes from National Semiconductors and IRF.
Overall, i like the other book better. The chapter layouts speak to the intended purpose of the books. In this book, the progression is from the start of an off-line power supply to then end. instead of starting with what the switching power supply is, and such, this book starts with input circuitry and startup methods. some suitable off-line topolgies are detailed. It is only later in the book that the basic switching power supplies, like the buck converter are detailed. It makes sense -- these supplies are billed for regulation in the book.
I found some of this book annoying. for instance, the author often refers to bifilar windings. there is no glossary entry for this. the index refers to multiple pages where "bifilar" is mentioned, but it is never defined. Similarly, "flyback" is not defined.
if you want to learn power supplies, i reccomend the book by Abraham I. Pressman over this one.
Summary: What an adventure!
Rating: 5
I did the right thing - I ordered this AND the venerable Abrahamson book. Up until that time I had only discerned the subject in hints and veiled inter departmental discussions - and it was the start of a wonderful two months period in which so much was revealed - I have rarely enjoyed a book so much! Now look, I don't work for Mr Amazon.com, but I would urge you to get both. This book (the one by Keith Billings) has lots of detail which the Abrahamson book skips a wee bit. They dovetail together beautifully - and the Abrahamson book includes a bit more breadth on the possible topologies. One of my favorite chapters in THIS book is the excellent exposition on biploar and FET drive circuits. Its made very clear - this man is a BORN teacher... This book even tells you how to select fuses, filter capacitors (the point being that the values you chose last month might well be right, but after this text you will know with far greater confidence, as it were) I must say that the one thing that both books are a little light on is the subject of CUK convertors, which I will have to get wisdom on from elsewhere I guess. The other thing that NEITHER books mention, which in fact is hard to find, is the design of planar transformers. This is a complex area involving quite a lot of maths, so I've been told. You can find some material in IEEE transactions on power electronics, and similar journals, but you may have to hunt a bit. Philips / Ferroxcube are good for this, too. The Abrahamson book covers current fed convertors. This includes a section on flyback current fed convertors - in which I think he forgot to elaborate on the case where the input transformer returns to the input, rather than the output, which appears to reduce input ripple and improves the power factor. But this case is handled quite well in the references given at the end of the chapter, so no matter. Its a very exciting chapter - but the Billings book doesn't cover them at all, which is a pity, since there's quite a lot of utility for these very stable topologies, involving quite light voltage and current strain on the switching transistors. I wish the books could go on even further, but all I can be is grateful... I must say also that the safety aspect of design is covered well in both books, both European and American.
Summary: Excelent refernce source
Rating: 5
This book does an excelent job of providing facts and information needed to design switchmode supplies. It gives numerical examples and shows the underlying theories.
有朋友需要这本书,帮忙上传了,希望有用,Enjoy~!~
[ 本帖最后由 benemale 于 2008-9-23 21:46 编辑 ]
Switchmode Power Supply Handbook, Second Edition.rar
4.68 MB, 下载次数: 882 , 下载积分: 资产 -3 信元, 下载支出 3 信元
发表于 2008-9-24 08:50:14 | 显示全部楼层
thank u
发表于 2008-9-24 09:01:42 | 显示全部楼层
Thank you very much!!
发表于 2008-9-24 09:07:41 | 显示全部楼层
hehe
火星大好人!
发表于 2008-9-24 09:12:15 | 显示全部楼层
没有目录
呵呵
发表于 2008-9-24 09:17:04 | 显示全部楼层
 楼主| 发表于 2008-9-24 09:35:33 | 显示全部楼层
原帖由 nesta 于 2008-9-24 09:12 发表
没有目录
呵呵
是的,Mcgraw-hill的书都是木有Front matter的,要自己去amazon截图。。。
不过我自己在pdf文档里做了一个书签目录,点左边的书签可以看到,将就着看吧,呵呵。。。
[ 本帖最后由 benemale 于 2008-9-24 18:50 编辑 ]
发表于 2008-9-24 09:44:06 | 显示全部楼层
发表于 2008-9-24 10:13:27 | 显示全部楼层
Good one
发表于 2008-9-24 11:14:05 | 显示全部楼层
wow,very nice
GMT+8, 2025-12-23 23:28 , Processed in 0.064375 second(s), 8 queries , Gzip On, Redis On.
