查看: 17201|回复: 58
cadence ldv51 的安装?
发表于 2008-6-22 10:06:52 | 显示全部楼层 |阅读模式
我在 ubuntu 下面安装
进入安装文件所在的目录,敲入: ./SETUP_SH
就有了如下的error message:
Setting up softload for lnx86 in /home/lingkai/ldv51
The following tar errors were detected:
/bin/tar: Removing leading `/' from member names
Could not set up SoftLoad in /home/lingkai/ldv51
You must have write permissions to install directory and all its subdirectories
and atleast 10 MB available disk space in install directory.
发表于 2008-7-12 11:22:18 | 显示全部楼层
Thanks
发表于 2009-4-27 09:42:34 | 显示全部楼层
注意你是不是用的root权限.
根据系统提示来看,你的目录可写空间不够,应该是权限不够造成的
发表于 2009-4-29 20:54:18 | 显示全部楼层
你英文好差阿
发表于 2009-5-14 21:32:48 | 显示全部楼层
兄弟,ubunt上装不成ncverilog,换redhat Enterprise 4 就可以了!
发表于 2009-5-15 14:26:39 | 显示全部楼层
thanks for your sharing!
发表于 2009-5-20 17:48:04 | 显示全部楼层
thanks for your sharing! ok that is good.
发表于 2009-5-20 19:35:08 | 显示全部楼层
发表于 2009-5-20 19:36:29 | 显示全部楼层
发表于 2009-5-20 19:37:47 | 显示全部楼层
GMT+8, 2025-12-15 01:32 , Processed in 0.023697 second(s), 7 queries , Gzip On, Redis On.
