查看: 6187|回复: 12
Modeling Semicondutor Devices using the VHDLAMS
发表于 2008-6-20 19:12:34 | 显示全部楼层 |阅读模式
 Introduction
         Simulation and Modeling
            Simulation
         Modeling
     Motivation
         Limitations of SPICE
     Merits of VHDLAMS
     Problem Statement
     Summary of Results
     Outline of the Thesis
 Background
     Levels of modeling
 Device models
     Physical device models
 Equivalentcircuit models
 SPICE Elemental Models
     MOSFET elemental models
         First Generation Models
     Second Generation Models
     Third Generation Models
 Related Research
 Model Theory and Equations
     SPICE Models
ii
         Diode Models
             Static Model
         Large Signal Model
     BJT Models
         Static Model
     Large Signal Model
     JFET Models
         Static Model
     Large Signal Model
     MOSFET Models
         Static Model
     Large Signal Model
 VHDLAMS Models
     Rules and Guidelines
 VHDLAMS Model Set
     Diode models
         Static model
     Large Signal Model
 BJT models
     static model
 Largesignal model
 MOSFET models
     Static model
 Largesignal
 JFET models
     Static model
     Performance Evaluation
     Criteria
 Evaluation
Conclusions and Future Work
     Conclusions
 Future Work
Bibliography
A Additional Results
iii
A     Factors Eecting SEAMS Execution Time
A Diode Static Model
A     Halfwave rectier
A Voltage doubler
A Largesignal model of a diode
A     Voltage Doubler
A DC Restorer
A Static Model of BJT
A     npn Dierential Amplier
A Output Characteristics of a pnp BJT
A Largesignal Model of a pnp BJT
A     pnp Switch
A Output Characteristics of a pchannel JFET
A Static Model of MOSFET
A     nMOS inverter
A pMOS inverter
A CMOS inverter
A CMOS buer
A nMOS inverter with largesignal model of nMOS
B VHDLAMS Code
B     Package Electrical System
B Signal generators
B     Rampwave Generator
B Sinewave generator
B Squarewave Generator
B Input from a File
B Static Model of Diode
B     Curve Tracer Circuit
B Halfwave Rectier
B Voltage Doubler
B Largesignal Model of a diode
B     Halfwave Rectier
B Voltage Doubler
B DC Restorer
B Static models of npn and pnp BJT
B     Curve Tracer Circuit for a npn BJT
B Curve Tracer Circuit for a pnp BJT
iv
B npn Common Emitter Amplier
B npn Dierential Amplier Circuit
B Largesignal models of npn and pnp BJTs
B     npn Switch
B pnp Switch
B Static Models of JFET
B     Curve Tracer circuit for nchannel JFET
B Curve Tracer arrangement for pchannel JFET
B Static Models for MOSFETS
B     NMOS inverter with enhancement NMOS load
B PMOS inverter circuit with depletion PMOS load
B CMOS Inverter
B CMOS Buer Circuit
B Largesignal Models of NMOS and PMOS Transistors
B     NMOS inverter with largesignal model of NMOS
B PMOS inverter with Largesignal model of a mos transistor
modeling_using_VHDL AMS.pdf
787.46 KB, 下载次数: 112 , 下载积分: 资产 -2 信元, 下载支出 2 信元
头像被屏蔽
发表于 2008-6-20 22:07:15 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2008-6-20 23:01:01 | 显示全部楼层
good, thanks
发表于 2008-11-11 23:11:28 | 显示全部楼层
十分感谢
发表于 2009-5-25 22:45:13 | 显示全部楼层
谢谢分享!
发表于 2009-10-5 00:46:12 | 显示全部楼层
dddddddddddddddddddddd
发表于 2009-10-5 23:22:42 | 显示全部楼层
非常感谢啊!!!
发表于 2009-10-10 07:29:02 | 显示全部楼层
谢谢分享
发表于 2009-10-28 20:41:26 | 显示全部楼层
kk看看
发表于 2010-3-29 11:42:07 | 显示全部楼层
学习一下啊
GMT+8, 2025-12-26 14:43 , Processed in 0.025667 second(s), 4 queries , Gzip On, Redis On.
