查看: 12678|回复: 52
Predicting the Phase Noise and Jitter of PLL-Based Frequency Synthesizers
发表于 2008-6-17 09:50:59 | 显示全部楼层 |阅读模式
利用VERILOG A建模
Contents
1 Introduction 2
1.1 Frequency Synthesis 3
1.2 Direct Simulation 3
1.3 When Direct Simulation Fails 4
1.4 Monte Carlo-Based Methods 4
1.5 Predicting Noise in PLLs 5
2 Phase-Domain Model 6
2.1 Small-Signal Stability 9
2.2 Noise Transfer Functions 9
2.3 Noise Model 11
3 Oscillators 12
3.1 Oscillator Phase Noise 12
3.2 Characterizing Oscillator Phase Noise 14
3.3 Phase-Domain Models for the Oscillators 16
4 Loop Filter 17
5 Phase Detector and Charge Pump 17
6 Frequency Dividers 18
6.1 Cyclostationary Noise. 19
6.2 Converting to Phase Noise 20
6.3 Phase-Domain Model for Dividers 21
7 Fractional-N Synthesis 22
8 Jitter 23
8.1 Jitter Metrics 24
8.2 Types of Jitter 26
9 Synchronous Jitter 27
9.1 Extracting Synchronous Jitter 28
10 Accumulating Jitter 30
10.1 Extracting Accumulating Jitter 32
11 Jitter of a PLL 34
12 Modeling a PLL with Jitter 34
12.1 Modeling Driven Blocks 34
12.2 Modeling Accumulating Jitter 36
12.3 VCO Model 37
12.4 Efficiency of the Models 38
13 Simulation and Analysis 44
14 Example 46
15 Conclusion 46
15.1 If You Have Questions 47
PLLnoise+jitter.pdf
666.26 KB, 下载次数: 476 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2008-8-20 17:37:43 | 显示全部楼层
这个帖子是要回的,谢谢楼主
发表于 2008-8-24 18:45:13 | 显示全部楼层
多谢了,
LZ介绍的比较详细啊
发表于 2008-8-24 23:01:34 | 显示全部楼层
Trade-Offs In Analog Circuit Design
发表于 2008-8-25 16:29:11 | 显示全部楼层
thansk
thanks
发表于 2008-8-25 16:33:06 | 显示全部楼层
thks
thanks a lot for your information.
Good luck
发表于 2008-8-26 17:24:04 | 显示全部楼层
xiexie
发表于 2008-8-28 00:53:45 | 显示全部楼层
thanks a lot
发表于 2008-9-27 21:32:56 | 显示全部楼层
学习了。谢谢楼主。
发表于 2009-2-22 13:20:01 | 显示全部楼层
Thank you
GMT+8, 2025-12-25 09:20 , Processed in 0.715160 second(s), 4 queries , Gzip On, Redis On.
