楼主: cetband6
请教DAC SFDR仿真方法
发表于 2009-3-31 14:37:51 | 显示全部楼层
prof3 发表于 2009-3-19 15:26
SFDR simulation for ADC or DAC is a little bit different. Correctly predict SFDR for  DAC must follow! {& O( }+ T- g, R" j) u
(1) Proper # of Pts in FFT and your simulation, basically, you need odd number of cycle of signal and have to keep 2^N ppt FFT. E.g. 10bit DAC, best case is to use 1024 pt. Depending on simulation time, most of case 256 pt  can also give us good SDFR prediction.7 g: k) k5 x9 f; I  r( G' ]
4 |2 m: t( q* {% D& j, T5 i3 M
I don't agree above author said that increasing # of cycle have no use. This is because your cycle repeating. If cohence sampling cycle, definitely helps.
(2) Pls take out the unsettling or overshoot point during the transient simulation. That is to say, you must use true settling points for FFT. Otherwise your SDFR is harm.+ z, G, t3 @6 t
4 f) O3 y+ O( X  s3 h# s
在用matlab做分析时可以将unsettling or overshoot point取出来,但是实际用仪器测试时能否去除掉呢,毕竟输出是连续变化的,整个输出做fft分析
[ 本帖最后由 iatb 于 2009-3-31 14:39 编辑 ]
发表于 2009-3-31 14:55:10 | 显示全部楼层
支持楼主
支持楼主
发表于 2009-3-31 16:27:03 | 显示全部楼层
very agree with pros says
发表于 2009-6-18 11:08:42 | 显示全部楼层
学习。。。。。。
发表于 2009-6-28 14:22:52 | 显示全部楼层
当不了沙泼还是要支持的!!!感谢感谢~~~
发表于 2009-8-25 17:43:42 | 显示全部楼层
xue xi le
发表于 2009-8-31 22:36:55 | 显示全部楼层
sample point=2^n
发表于 2009-10-27 23:56:29 | 显示全部楼层
study
发表于 2009-12-6 13:33:10 | 显示全部楼层
找不到原文,想学习一下
发表于 2009-12-9 20:19:12 | 显示全部楼层
谢谢楼主的分享了!
GMT+8, 2025-12-28 05:26 , Processed in 0.021420 second(s), 4 queries , Gzip On, Redis On.
