查看: 3468|回复: 0
help: 在linux 下交叉编译问题(使用硬浮点vfp)
发表于 2008-6-3 17:02:31 | 显示全部楼层 |阅读模式
I am trying to using my GNU toolchain that compiles to hard VFP
instructions*for me to run under linux on ARM.(arm926ej-s with vfp9s)
with the cmd:
     arm-uclibc-linux-gcc -mfpu=vfp -mfloat-abi=softfp -O2 -mcpu=arm926ej-s  h.c -o h_vfp
But there is a ld error;
     ld: Error:  /tmp/ccmw16sq.o uses VFP instructions, wheres h_vfp does not
     ld: failed to merge target specific data of file /tmp/ccmw16Sq.o
is that gcc or glibc must rebuild with some vfp option?
Any idea what I should do?
thanks
boor
GMT+8, 2025-12-18 10:00 , Processed in 0.017600 second(s), 7 queries , Gzip On, Redis On.
