查看: 4093|回复: 5
Help! VCS and NC-SIM
发表于 2008-6-3 05:56:25 | 显示全部楼层 |阅读模式
Anyone knows what is the command line for VCS and/or NC-SIM that does the same thing as the following one in Modelsim?
vsim -c -do "run 1000;quit" work.top
basically, I just want my testbench to run for only 1000 time units, and I want to run it in script mode of VCS and NC-SIM. (not in GUI)
Any suggestion helps. Thanks.
 楼主| 发表于 2008-6-3 07:13:26 | 显示全部楼层
Just finished reading the User Guide of VCS.
here is how to make it work with two line
vcs *.v
./simv +vcs+stop+1000 or ./simv +vcs+finish+1000
 楼主| 发表于 2008-6-3 08:47:04 | 显示全部楼层
I finally found out how it works in nc-sim now.
here is it
ncsim worklib.top:v -input "@run 1000;exit"
Thanks for your concerns ^^ and I am still open for any better idea.
发表于 2009-2-22 13:15:47 | 显示全部楼层
eetopeetop
发表于 2009-5-23 00:01:41 | 显示全部楼层
不断地赚钱啊
发表于 2011-2-27 12:05:27 | 显示全部楼层
Hey, how can u use Synopsys VCS? Crack it? I installed VCS7.0.1 successfully, but it says invalid license in the terminal when I compile my Verilog file. U know what, the license I used was generated by EFA LicGen0.4b, and it is working at Design Compiler 200809.....strange!
GMT+8, 2025-12-19 18:10 , Processed in 0.016984 second(s), 5 queries , Gzip On, Redis On.
