查看: 2793|回复: 1
弱弱的寄存器的问题
发表于 2008-5-28 10:28:41 | 显示全部楼层 |阅读模式
请问一下各位存储一个数字9是不是需要一个四位的寄存器?
还有麻烦各位高人帮我看一下这个时钟计数器程序哪有错误,编译可以通过但是仿真结果不对。谢谢了。
module COUNTER (NEW_CURRENT_TIME, LOAD_NEW_C, CLK, RESET,CURRENT_TIME);
   input NEW_CURRENT_TIME;
   input LOAD_NEW_C;
   input CLK;
   input RESET;
   output[5:0] CURRENT_TIME;
   wire[5:0] CURRENT_TIME;
   reg[5:0] I_CURRENT_TIME;
   always @(posedge CLK or posedge RESET or posedge LOAD_NEW_C)
   begin : xhdl_1
      reg[5:0] C_T;
      if (RESET == 1'b1)
      begin
         I_CURRENT_TIME[5] <= 0 ;
         I_CURRENT_TIME[4] <= 0 ;
         I_CURRENT_TIME[3] <= 0 ;
         I_CURRENT_TIME[2] <= 0 ;
         I_CURRENT_TIME[1] <= 0 ;
         I_CURRENT_TIME[0] <= 0 ;
      end
      else if (LOAD_NEW_C == 1'b1)
      begin
         I_CURRENT_TIME <= NEW_CURRENT_TIME ;
      end
      else
      begin
         C_T =I_CURRENT_TIME;
         if (C_T[0] < 9)
         begin
            C_T[0] = C_T[0] + 1;
         end
         else
         begin
            C_T[0] = 0;
            if (C_T[1] < 5)
            begin
               C_T[1] =C_T[1] + 1;
            end
            else
            begin
               C_T[1] = 0;
               if (C_T[2] < 9)
               begin
                  C_T[2] =C_T[2] + 1;
               end
               else
               begin
                  C_T[2] = 0;
                  if (C_T[3] < 5)
                  begin
                     C_T[3] =C_T[3] + 1;
                  end
                  else
                  begin
                     C_T[3] = 0;
                     if (C_T[5] < 2)
                     begin
                        if (C_T[4] < 9)
                        begin
                           C_T[4] =C_T[4] + 1;
                        end
                        else
                        begin
                           C_T[4] = 0;
                           C_T[5] = C_T[5] + 1;
                        end
                     end
                     else
                     begin
                        if (C_T[4] < 3)
                        begin
                           C_T[4] =C_T[4] + 1;
                        end
                        else
                        begin
                           C_T[4] = 0;
                           C_T[5] = 0;
                        end
                     end
                  end
               end
            end
            I_CURRENT_TIME<= C_T;
         end
      end
   end
  assign CURRENT_TIME =I_CURRENT_TIME ;
endmodule
 楼主| 发表于 2008-5-28 19:43:12 | 显示全部楼层
各位高人帮忙看一下啊,呵呵!
万分感谢!
GMT+8, 2025-12-17 20:07 , Processed in 0.014427 second(s), 6 queries , Gzip On, Redis On.
