查看: 8129|回复: 0
关于set_dft_signal里的参数的问题
发表于 2008-5-16 09:50:03 | 显示全部楼层 |阅读模式
想问一下,-view
existing_dft | spec,这两个选项有什么区别,在进行扫描插入的时候该如何设置?比如所我一个design里,有一个全局的reset和clock信号,在模块端口有reset和clock引脚。另外还加了tm,se,si,so的空端口,对于这些reset, clock, tm,se,si和so,应该设置成existing_dft还是spec呢?
man下该命令,原文是如下,不是很理解,故提问,还请高人帮人解疑下……
Indicates the view to which the specification applies. Valid views are
existing_dft: This implies that the specification refers to the existing usage of a port. For example, to describe that port A is used as a scan enable, enter
set_dft_signal -view existing_dft -port A -type ScanEnable
This is used when working with DFT inserted designs.
spec (default) : This implies that the specification
refers
to ports
that the tool must use during DFT insertion. For example, to prescribe that port A is used as a test enable, enter
set_dft_signal -view spec -port A -type ScanEnable
This is used when preparing a design for DFT insertion
GMT+8, 2025-12-16 02:40 , Processed in 0.015037 second(s), 7 queries , Gzip On, Redis On.
