查看: 27561|回复: 204
HIGH PERFORMANCE CLASS-D AMPLIFIERS 博士论文
发表于 2008-4-15 20:42:44 | 显示全部楼层 |阅读模式
2007,Texas Tech University,HIGH PERFORMANCE CLASS-D AMPLIFIERS
HIGH PERFORMANCE CLASS-D AMPLIFIERS by CHINTAN TREHAN, B.E.pdf
3.17 MB, 下载次数: 982 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2008-4-15 22:16:49 | 显示全部楼层
Thanks very much.
发表于 2008-4-16 01:26:08 | 显示全部楼层
好的好的好的好的
发表于 2008-4-16 09:38:55 | 显示全部楼层
qqqqqqqqqqqqqqqqqqqqqqqqqqqqqq
发表于 2008-4-16 15:01:42 | 显示全部楼层
发表于 2008-4-17 08:54:25 | 显示全部楼层
thank you very much
发表于 2008-4-17 09:10:43 | 显示全部楼层
THANKS!!
发表于 2008-4-17 15:49:15 | 显示全部楼层
:victory:
发表于 2008-5-7 15:22:24 | 显示全部楼层
qqqqqqqqqqqqq
发表于 2008-5-7 15:38:21 | 显示全部楼层
This dissertation presents several improvements to the standard digital input class-
D amplifier architecture. Three different architectures of class-D amplifier have been
proposed as part of this work, and their theoretical verification is done by system-level
simulations. The output stage in all the proposed architecture is driven by Sigma-Delta
Modulation (SDM). The first consists of a delay-line analog-to-digital converter in the
feedback. The second architecture achieves feedback using continuous-time SDM. The
third structure does not employ feedback but suppresses noise using a three-level output
stage. System-level simulations are carried out using MATLAB and SIMULINK. The
structures are then taken through the schematic design and layout using the CADENCE
design suite. The first design is fabricated through the MOSIS design foundry. The
fabricated device is then tested using a custom made test PCB. The results of the testing
are analyzed, and ideas for future enhancements to the overall topology have been
specified.
GMT+8, 2025-12-30 10:56 , Processed in 0.029613 second(s), 6 queries , Gzip On, Redis On.
