查看: 3043|回复: 3
哪位朋友能帮我检查下关于TAP CONTROLLER的代码?
发表于 2008-4-13 05:44:19 | 显示全部楼层 |阅读模式
I am using Board FPGA Spartan3 and want to readback using JTAG TDO pin,the following is part of my source code (based on the TAP statemachine):
My question is that it seems that no data is clocked  out of the TDO pin
process (JCLK)
begin
if rising_edge(JCLK) then
    if (COUNTER = 17) then               -- IDCODE Bit 5=0
            TMS <= '0';
            TDI <= '0';
        end if;
        if (COUNTER = 19) then --IDCODE Bit 6 (MSB)=0    --Exit-IR1
            TMS <= '1';         --Update-IR               --Select-DR-Scan
            TDI <= '0';
        end if;
        if (COUNTER = 25) then --Capture-DR              --Shift-DR
            TMS <= '0';
            TDI <= '0';
        end if;
        if (COUNTER = 29) then --
           TMS <= '0';
            DATAOUT_SIG(0) <= TDO;
        end if;
        if (COUNTER = 31) then
           TMS <= '0';
            DATAOUT_SIG(1) <= TDO;
        end if;
TDO is   definited in the entity as   : in std_logic;                       --Test Data Out
and DATAOUT_SIG is signal of 32 bits width.
Can any one perhaps tell me where is wrong with this using style of readback IDCODE?
发表于 2008-4-14 08:52:35 | 显示全部楼层
你到底要干什么?说的再清楚一些!
发表于 2008-4-14 13:07:11 | 显示全部楼层
是JTAG的吗?
 楼主| 发表于 2008-4-16 20:41:21 | 显示全部楼层
是的是JTAG;我想利用xilinx 的UG332中的TAP State Machine回读配置文件
但是编写的VHDL代码貌似没有将1其读出来,从TDO上读的都是0,不知道哪位大人有经验,能帮我看看可能出错在什么地方。
急等!
我的邮箱traeumerlingling@hotmail.com
GMT+8, 2025-12-30 10:56 , Processed in 0.025043 second(s), 7 queries , Gzip On, Redis On.
