查看: 4325|回复: 12
Sample-and-Hold Circuit__論文
发表于 2008-3-14 18:30:44 | 显示全部楼层 |阅读模式
Low Power, High Performance Sample-and-Hold Circuit__論文
This master thesis describes the design of a track-and-hold (T&H) circuit
with 10bit resolution, 80MS/s and 30MHz bandwidth. It is designed in a
0.18μm CMOS process with a supply voltage of 1.8 Volt. The circuit is
supposed to work together with a 10bit pipelined analog to digital converter.
A switched capacitor topology is used for the T&H circuit and the amplifier
is a folded cascode OTA with regulated cascode. The switches used are of
transmission gate type.
The thesis presents the design decisions, design phase and the theory needed
to understand the design decisions and the considerations in the design
phase.
The results are based on circuit level SPICE simulations in Cadence with
foundry provided BSIM3 transistor models. They show that the circuit has
10bit resolution and 7.6mW power consumption, for the worst-case
frequency of 30MHz. The requirements of the dynamic performance are all
fulfilled, most of them with large margins
发表于 2008-3-14 19:54:19 | 显示全部楼层
xiexeifenxaing
发表于 2008-3-14 19:58:51 | 显示全部楼层
好资料,下来看看!!
发表于 2008-3-14 21:35:11 | 显示全部楼层
Where!!!!!!!!!!!!!
 楼主| 发表于 2008-3-14 21:38:54 | 显示全部楼层
头像被屏蔽
发表于 2008-8-17 18:31:19 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2009-6-27 16:38:19 | 显示全部楼层
发表于 2009-6-27 20:42:49 | 显示全部楼层
thanks for sharing
发表于 2009-8-16 19:45:39 | 显示全部楼层
thank you
发表于 2009-11-16 02:47:25 | 显示全部楼层
感謝分享囉
應該寫的很不錯
GMT+8, 2025-12-28 08:47 , Processed in 0.023835 second(s), 6 queries , Gzip On, Redis On.
