查看: 15809|回复: 73
免费:Hardware design Guideline with Verilog-RTL
发表于 2008-3-13 18:58:29 | 显示全部楼层 |阅读模式
As design circuit size gets larger, efficient reuse of design property has become extremely important.
The design property, which is also called IP (Intellectual Property), is essential technology to
realize System-on-a-Chip.
The organization called VSI (Virtual Socket Interface) is now trying to commonize IP to enable us
to structure a system by purchasing IP from multiple vendors that a large-scale system can easily
be integrated into a single chip. Therefore, a circuit, which is larger than conventional ones, can
be designed within the similar timeframe.
Software IP is described in RTL (Register Transfer Level) by using mainly HDL (Hardware Description
Language).
By having IP described in RTL, changes can easily be made to the HDL description. Also, in the
parameterized descriptions, a circuit can easily be changed according to the object of an application.
These software IP are realized in gate level circuits at the end by using logic synthesis tools and by
specifying design constraints and technology.
The design constraint includes specification of timing condition, area, and operation environment
etc. as the required circuit performance. If the constraint given at the time of synthesis is not
appropriate, the circuit may be synthesized incorrectly and therefore it becomes unlikely to meet
the target performance. If description is not appropriate, it will also become hard to meet the
target performance.
[ 本帖最后由 xudeqiang 于 2008-3-13 19:02 编辑 ]
DesignStyleGuide_Verilog.part1.rar
4.77 MB, 下载次数: 360 , 下载积分: 资产 -3 信元, 下载支出 3 信元
DesignStyleGuide_Verilog.part2.rar
1.59 MB, 下载次数: 333 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2008-6-20 00:26:25 | 显示全部楼层
thank Xu
发表于 2008-6-22 17:47:08 | 显示全部楼层
ddddddddddddddddddddd
发表于 2008-6-22 17:49:06 | 显示全部楼层
222  xia
发表于 2008-6-22 18:55:38 | 显示全部楼层
very very good
发表于 2008-6-23 13:29:54 | 显示全部楼层
good very good
发表于 2008-6-30 11:06:15 | 显示全部楼层
waiting for so long , Now , it is free ,
Thanks a lots
发表于 2008-6-30 11:13:44 | 显示全部楼层
Thanks very much.
发表于 2008-7-10 11:30:01 | 显示全部楼层
很好的資料,感謝大大無私的分享。
发表于 2008-7-14 01:45:51 | 显示全部楼层
thanks
GMT+8, 2025-12-19 12:32 , Processed in 0.029636 second(s), 6 queries , Gzip On, Redis On.
