查看: 11566|回复: 16
[求助] innovus 18.1 cts问题
发表于 2019-8-3 16:37:25 | 显示全部楼层 |阅读模式
ccopt_design -cts
(ccopt_design): CTS Engine: auto. Used Spec: pre-existing CCOPT spec.
**ERROR: (IMPTCM-162):        "" does not match any object in design for specified type "layer " object in command "create_route_type".
Usage: create_route_type [-help] [-em_ndr_dist <float>] [-em_ndr_rule <rule_name>] -name <string>
                         [-one_side_spacing_range <bottomLayerNum:topLayerNum] [-shield_side {one_side both_side}] [[[-non_default_rule <ndr_name>] [-shield_net <net_name>] [-bottom_shield_layer <layer>] [-top_preferred_layer <layer>] [-bottom_preferred_layer <layer>] [-preferred_routing_layer_effort {low medium high}]] | [-table <string> [-table_length_type {total source_to_sink}]]] [-mask <mask_number> [-layer_mask_range <bottomLayerNum:topLayerNum>]]
**ERROR: (IMPTCM-4):        The value "" specified for the object type of argument "-top_preferred_layer" is not valid. Review the command specification and remove the argument or specify a legal value.
Placement constraints of type 'region' or 'fence' will not be downgraded to 'guide' because the property change_fences_to_guides has been set to false.
总是报create_route_type 命令的错误,使用的命令如下:
add_ndr -name CTS_1W1S -width { M3 0.46 M2:M1 0.28} -spacing {M3 0.44 M2:M1 0.28}
create_route_type -name leaf_rule  -non_default_rule CTS_1W1S -top_preferred_layer M3 -bottom_preferred_layer M3
create_route_type -name trunk_rule -non_default_rule CTS_1W1S -top_preferred_layer M3 -bottom_preferred_layer M2
set_ccopt_property -net_type leaf  -route_type leaf_rule
set_ccopt_property -net_type trunk -route_type trunk_rule
set_ccopt_property -net_type top   -route_type leaf_rule
请问这个问题出在哪里?
发表于 2019-8-4 21:57:56 | 显示全部楼层
把M3的M去掉
发表于 2019-8-5 17:09:05 | 显示全部楼层
楼主有INNOVUS18可以分享吗?
 楼主| 发表于 2019-8-8 08:52:42 | 显示全部楼层
sunnyliu 发表于 2019-8-5 17:09
楼主有INNOVUS18可以分享吗?
没有,公司正版软件,无法分享。
 楼主| 发表于 2019-8-8 10:43:56 | 显示全部楼层
试过了,依然报错 ,   M3,MET3, 3全试过了,全报一样的错。感觉不是这里的问题。
发表于 2020-7-7 14:27:58 | 显示全部楼层
楼主后续是如何解决的?碰到了一样的问题。谢谢!
 楼主| 发表于 2020-8-19 09:17:26 | 显示全部楼层
现在问题依然存在,没有解决
发表于 2020-8-20 19:34:50 | 显示全部楼层
M2:M1?? 有冒号?
发表于 2020-8-24 15:32:11 | 显示全部楼层
添加了一个一直提示不再支持的命令解决:
setCTSMode -routeBottomPreferredLayer 1 -routeTopPreferredLayer 3 -routeLeafBottomPreferredLayer 1 -routeLeafTopPreferredLayer 3
具体用什么可支持的命令还没搞清楚。
 楼主| 发表于 2020-9-3 12:24:06 | 显示全部楼层
楼上的,谢谢啦 ,虽然不知道为什么,但问题真的没有了。:hug::hug::hug::hug::hug::hug::hug::hug::hug::hug::hug::hug::hug::hug:
GMT+8, 2025-9-13 21:34 , Processed in 0.018444 second(s), 3 queries , Gzip On, Redis On.
