查看: 3291|回复: 1
[讨论] negative propagation delay为什么会是负数?
发表于 2013-10-2 22:13:45 | 显示全部楼层 |阅读模式
The SAGE-X Standard Cell Library may contain negative propagation delays. Although most third-party verification tools can handle negative propagation delays, some tools will turn negative delays into a zero value.
传输延时应该是个正数啊,怎么还有负数这种情况?
发表于 2014-4-25 10:14:22 | 显示全部楼层
回复 1# 729050850
   这个跟定义的百分比还有输入信号的slew、输出的负载有关系如果输入信号的rise time很小,而负载很大,那么delay肯定是正的
如果输入信号的rise time很大,而负载很小,那delay就不好讲了
GMT+8, 2025-11-9 19:31 , Processed in 0.012660 second(s), 5 queries , Gzip On, Redis On.
