在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 3542|回复: 1
[资料] MGC docs mis file installation guide
发表于 2010-9-15 07:28:18 | 显示全部楼层 |阅读模式
mis stands for Mentor Install Source.
Once you have the mentor program installed. There is a directory named "install.ixl". The "install (mgc_install)" is under install.ixl.
execute "install", the Mentor Graphic install window will show up.  --> select "Install Products". After that just follow the guide line, you can install mis file.
发表于 2010-10-7 20:24:02 | 显示全部楼层
Thank you very much
GMT+8, 2025-7-8 07:13 , Processed in 0.014183 second(s), 8 queries , Gzip On, MemCached On.
