查看: 2144|回复: 2
[求助] 请教一个verilog问题,谢谢!
发表于 2017-2-18 00:05:25 | 显示全部楼层 |阅读模式
  1. `ifdef D3D_SYNC_RESET
  2. always @(posedge clk_core) begin
  3. `else
  4. always @(posedge clk_core or negedge rst_x) begin
  5. `endif
  6.   if (rst_x == `D3D_RESET_POL) begin
  7.     r_state <= IDLE;
  8.   end else begin
  9.     case (r_state)
  10.       IDLE: begin
  11.         if (i_en) r_state <= LINE_0;
  12.       end
  13.       LINE_0: begin
  14.         if (i | w_reject_l0) r_state <= LINE_1;
  15.       end
  16.       LINE_1: begin
  17.         if (i | w_reject_l1) r_state <= LINE_2;
  18.       end
  19.       LINE_2: begin
  20.         if (i | w_reject_l2) r_state <= IDLE;
  21.       end
  22.     endcase
  23.   end
  24. end
    复制代码
请教下,这个里面的`ifdef,他是到`endif结束呢?还是把下面状态机运行完呢?假设D3D_SYNC_RESET已定义。谢谢!
发表于 2017-2-18 09:35:24 | 显示全部楼层
回复 1# qwer20
   ifdef与c语言中的含义一样,这里你假设D3D_SYNC_RESET已定义那么代码将变成
    r_state <= IDLE;
  end else begin
    case (r_state)
      IDLE: begin
      end
      LINE_0: begin
      end
      LINE_1: begin
      end
      LINE_2: begin
      end
    endcase
  end
end
而不是你想的状态机运不运行的问题,与这个无关
 楼主| 发表于 2017-2-18 19:09:03 | 显示全部楼层
回复 2# woai2020
懂了,谢谢!
GMT+8, 2025-9-10 11:03 , Processed in 0.398712 second(s), 3 queries , Gzip On, Redis On.
